R.Sanders Plant
Look like you are updating the fleet then Rory!,πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚πŸ˜‚
Yes, the right way... backwards πŸ˜‚
Na, it's come in for some bits to be sorted on it over Christmas. Slew Motor needs new bolts with correct torque. Diesel Leak on the lift pump, few cosmetic things and a potential leak on one of the drives. But for the Β£1800 that it cost initially it was cheap enough :eek: Wish I'd brought it tbh
As for going backwards, I was root ripping today and managed to catch the Engcon electrical feed on said stump. Without any tilt or rotate on the ripper I managed to get the offending root out. Put the bucket on and had to backfill the hole and tidy up the embankment it is on. I sat there and as much as I willed the bucket to dance around to do the required job it took my a while to work out I needed to track the digger into different places to do the required job. I was very relieved to find Engcon staff working late so i can get back to normal tomorrow!!
any plant man worth his salt doesn’t need a sledgehammer to change a bucketπŸ€” the secret is tip link firstπŸ‘
aye agreed (y) ...... but look at the state of those pins Mog :oops: πŸ˜‚
Bugger ....... does this mean my services won't be required :cry::cry::cry: πŸ˜‚
Same old Chaos...
Nice little job this week, Reduce dig to get the levels right around a house and a footing for a wall...
Unusual job for us as the quantity to come out is small, and the job is just big enough for a micro. Little HS400 Hinowa is a utter treat and the self loader is far more than a gimmick. πŸ₯°
Muckaway via the only Hiab I'd buy. Triple extension and full remote control 😍
