Only if your a plant fitterDo you still pay full days when it breaks down an hour into the shift?
Look like you are updating the fleet then Rory!,![]()
job's taken chaps![]()
I'm relocating to Devon for the duration
....... wiv me sledge hammer an' drift
aye agreedany plant man worth his salt doesn’t need a sledgehammer to change a bucketthe secret is tip link first
Bugger ....... does this mean my services won't be requiredYes, the right way... backwards
Na, it's come in for some bits to be sorted on it over Christmas. Slew Motor needs new bolts with correct torque. Diesel Leak on the lift pump, few cosmetic things and a potential leak on one of the drives. But for the £1800 that it cost initially it was cheap enoughWish I'd brought it tbh
@Gunners the worst thing is having skipped through the mag I fail to see you featuring anywhere else ?![]()
I heard he wanted to much money for the feature......”Hello” magazine got the first scoopHe had to pull the feature on him at the last minute, through fear of ridicule, shame on you all......
tha's a BIG hole for a drain pipe .... wouldn't wanna have to try and get down in that manholeSame old Chaos...
Nor would I. Never understood why anyone would use 300mm Chamberstha's a BIG hole for a drain pipe .... wouldn't wanna have to try and get down in that manhole![]()
Nor would I. Never understood why anyone would use 300mm Chambersbut we just do as requested
