well before
I could get up to anything ... there was the little matter of fixing
the boss's mirror ... got the new toy,
that i didn't need, out and made a couple of brackets in seconds
should've taken a pic with the tight bend tooling in, but forgot, before I changed it back to the
rad. tooling .... anyone doing any bending regularly .. get yerself one .. not as 'manly' as me old Goliath was but perfectly servicable ...
https://www.aimtools.co.uk/collections/bending-folding/products/165193?variant=17761316405337
brackets made, after sussing their required dim.s and fixing kit assembled ..
yon mirror got fixed the the wall ... with the brackets suitably packed/spaced out, to suit the nuances of the stonework ...
helped Pam getting a few
pot bound plants out of their pots ... bloody heavy .... tidied up a few loose ends from yesterday ... then wound up the 'Drema to lift the Auramo out from where it's been sat since not long after it arrived ... a significant time ago ... need a
fabbing fix
dropped it on the bench, dismantled its main components and separated 'em
dinky lil' rotary coupling
and some very interesting oil impregnated felt grease seals ...
keeping all the slimy stuff where it's supposed to be ...
this was not the assembly I was expecting to see ... but very clever .... and simple
nice check valve built onto the side of the ram....
explains why it won't open up any further than it has ...
not quite fully open
got it all cleaned up, flipped the slew ring over to keep it dry, in case we do get some wet stuff, as forecast overnight ..... and ran out of light .... but not before I'd hauled out a lump of plate and set out a few details, for a go tomorrow ...... after me
hamster juice, in the morning
and 'fore anyone else says it ..... yes that rotator'd make a nice MkII VA-r base
