Knew there was a
"can you just " coming when this was brekky .....
Tha's not a slice of toast!! "
and before anyone says it .... I can't eat eggs .. or too much at a time !!
a little and often
" so what you doin' today then Gra? ..... you know that mirror we were talking about " ... " the one i've been pondering HTF to hold on the wall you mean .... I have an idea brewing " now usually I'd just go and buy some mirror brackets ... but !!
these are lengths of vertical blind track that I'd gutted and burnt ... they were just sat under the bench as
'I knew' they'd cuminfa summat ......... and their time had come
the little bit in this pic was my trial sample to see how it'd fit/work ... well was the answer !!
so ..... had to take a flange off the one side ..... carefully
the short ones were easy ... the 1100 mm pieces were a bit more challenging
but got there and ended up with sufficient for the top and bottom of said mirror .... now mounting this on a stone wall was not going to be easy ... especially after i'd sussed just where she wanted it
gave up on a direct mount ... just wasn't going to happen .... without breaking a 5' x 2' x 8mm plate glass mirror
... so got me chippy head on and ......
didn't have a piece of ply big enough .... two strips that'd do but not in one piece
so make it a frame to keep it all in one piece ..... bearing in mind that Pam and Vicki have just about cleaned me out of 'sundry' timber with their planter boxes
so ripped a couple of pieces of 90 x 38 CLS in half .. again ... and gave it a bit of a rabbit (rebate to new heads)
if it'd been earlier n the day I'd have hauled me saw bench out .... but had it ripped with a fence and some careful depth settings, by the time i'd have dragged the bench out
out with the chop saw, set to 45 ... and create
this'll be a damned sight easier to fix to / hang on a stone wall, with said mirror attached to it ....... job for Pam tomorrow .. waterproof it ... paint or varnish'll be the decision of the day tomorrow - not mine
have managed a few other odds an' sods through the day .. pix tomorrow .. and cut the grass, beside the drive, with the Dane
Pam insisted on mowing the lawn (for a change) ... She'd been on the Countax 20 minutes, when it went quiet ... so trolled down to see why ......................... and she'd broken it
fortunately not a critical bit ... just the hand brake/brake lock ..... 'nother job for the list .... a new one ... not even I am gonna try welding that ..... although I could always re-drill the hole I suppose .... Hmmmmm !!
