Floaties are a must have for non black top useCould only dream of that round here...a duck off the tarmac![]()
There you go ready for the pour View attachment 18694
I think you do get high pressure insulation board for under heavy loaded concrete floors. Can't remember what it's called mindYep but I don't think you can put insulation under a floor you want to run potato lifters on![]()
I very much doubt they'll even notice it's heated then..heat will get sucked up by the cold base. Insanity. Must have money to burn litterally. Unless...it's a RHI "deal"Yep but I don't think you can put insulation under a floor you want to run potato lifters on![]()
I very much doubt they'll even notice it's heated then..heat will get sucked up by the cold base. Insanity. Must have money to burn litterally. Unless...it's a RHI "deal"![]()
very nice hole ThomasA kingspan klargester put in today at a barn conversion
They are going to have to keep that chicken locked away from next Monday because of bird flu...A kingspan klargester put in today at a barn conversion
Not if they eat it before then!!They are going to have to keep that chicken locked away from next Monday because of bird flu...
very nice hole Thomas... nice digging too BTLs
I take 2 x 1000l IBC and fill them up on job beforehand - then we aren't waiting for hosepipe.Yes it was a bit agricultural it was a piece of push panel to save getting ready mix tbh I'm not sure it was much easier than doing it with concrete as I ended up knocking up a couple of cube with the duck to cap the tank with to keep the BCO happy.
Biggest secret I've found to doing these tanks is to dig the hole fast get some conc or the panel in then get the tank in and start ballasting it with a hosepipe if you mess about and try to do it over a couple of days that's when you run into problems
I've got myself a trailer sorted for behind the duck
