T Whiting Excavations
T whiting
T whiting
Back home and new Led worklights fitted ready for the clocks changing
received_370185600701828.jpegreceived_1489487824773466.jpegreceived_271140830874609.jpeg
And the machine store and workshop floor trimmed to within 5mm ready for underfloor heating and concrete this weekreceived_701836907105612.jpegIMG_20201016_083427_6.jpg
Underfloor heating 😍 tell us more. Heat source, what pipe, how thick is slab, what's the control 🤔
T whiting
T whiting
I'm just doing the leaver pulling but it looks like spaghetti in there atm I'll grab some photos of the pipes down on Monday the slabs 180mm the reasoning for the tight tolerance is that they want to drill racking into the slab and the main contractor is worried about liability if they drill a pipe
Underfloor heating and pallet racking...😲😲
T whiting
T whiting
Yep nothing but luxury for those parts it sounds like it'll be a disaster but time will tell
Dont speak to me about ufloor htg....grundfoss has packed in ..only 2 years old.
But seriously underfloor htg in a warehouse with racking? How much kingspan under that lot?🙄😲
Turn it on then use a flir ir camera before they drill.
We had a jobbie in a new building in invergordon 2 winters ago, they had underfloor heating running off air source heat pumps, was set at 14degrees ☺️ was only allowed 70mm depth into slab. Was shitting it with every hole we drilled.
Pipes were 120 down but you never know when pouring concrete if a plastic pipe could lift 50mm during the pour no problem.
Horrible feeling innit? Like defusing a bomb.
Saw a clever heat reactive plastic sheet once for electric cable type.you laid it out and in changed colour with heat so you could see the wires clear as anything. Weather it work with pipes I often wondered. Very handy.
T whiting
T whiting
Right I've moved onto a little job 48m of perforated drain for a designed soakaway for the barn conversions my dad's just started sorted the leaves for all the drainage all finished and the old farmyard scraped down to decent stone for working off in 3 days with just me and the duck
