T Whiting Excavations
T whiting
T whiting
It's clay ground and properly shitty on the top, I was supprised how well it stayed on top those floaty boots really do keep it up on the surface.
Yep but I don't think you can put insulation under a floor you want to run potato lifters on 😯
I think you do get high pressure insulation board for under heavy loaded concrete floors. Can't remember what it's called mind 🤔
I very much doubt they'll even notice it's heated then..heat will get sucked up by the cold base. Insanity. Must have money to burn litterally. Unless...it's a RHI "deal" 🤔
F
fred
underfloor heating is very efficient especially when powered by a ground source heat pump, can get COP values of 8 meaning £1 of electric gives you £8 of heat. For the minimal cost of 100mm celotex that would at least double the efficiency its crazy.
Got to love the RHI free farmer money!!!
T whiting
T whiting
A kingspan klargester put in today at a barn conversion
T whiting
T whiting
very nice hole Thomas :love: ... nice digging too BTLs (y):cool:
Yes it was supposed to be running sand (why I was there the person who's coming to do all the drainage has a 6t but didn't want to tackle the tank) but is was nothing but nice hard clay all the way we were just peeking into the sand as we got to depth
They are going to have to keep that chicken locked away from next Monday because of bird flu...
Are there restrictions for birds coming in?
Apparently they went to pick so e stuff up from another farm and found it in there trailer when they got home it gets everywhere it was in the kitchen fitters van and apparently it found its way onto the top lift of the scaffold when the barn was scaffolded
diggerjones
diggerjones
Did i spy preformed concrete under the tank. Was it the same as gas tanks.
I've got to do one in the near future.
T whiting
T whiting
Yes it was a bit agricultural it was a piece of push panel to save getting ready mix tbh I'm not sure it was much easier than doing it with concrete as I ended up knocking up a couple of cube with the duck to cap the tank with to keep the BCO happy.
Biggest secret I've found to doing these tanks is to dig the hole fast get some conc or the panel in then get the tank in and start ballasting it with a hosepipe if you mess about and try to do it over a couple of days that's when you run into problems
I take 2 x 1000l IBC and fill them up on job beforehand - then we aren't waiting for hosepipe.
T whiting
T whiting
Yes that's how we did this one farmer had a sprayer tank so it would fill a ibc in a couple of minutes I normally find that if the water pressure is good the water is coming out the outlet by the time it's backfilled
T whiting
T whiting
I've got myself a trailer sorted for behind the duck I just need to give it a coat of shiny tish.
Any recommendations for paint @V8Druid ?
diggerjones
diggerjones
I will have to see what bc says about concrete under it.
