looks a good deal .. might need to take a look at one of theseNot a bad price less than 300 gets you kit with guide rail too
Is it this one ?There is a specific shaped steel blade for the Evolution saw. I had one to chop up the old 3mm steel oil tank.
Worked OK to cut out some 6mm steel plate yesterday.
more likely to be this 60 toother I'd've thought
Says specifically designed for ssmore likely to be this 60 toother I'd've thought
That’s one for stainless steel bud . The dark blue ones are steel . I’ve not seen one the same as spurrys onemore likely to be this 60 toother I'd've thought
Spurry’s one is the ‘basic’ one, more for cutting wood with nails etc, or small amounts of steel.That’s one for stainless steel bud . The dark blue ones are steel . I’ve not seen one the same as spurrys one
I looked into that but was advised againstit because for cold cut it needs to travel at a different speed or the filings stick to the panels and rustHad a load of panels ,50m insulation and tin both sides m,cut with petrol disc cutter with metal blade ,no probs
surely the ridge is going to be flashed so no exposure to the wet stuff ?I looked into that but was advised againstit because for cold cut it needs to travel at a different speed or the filings stick to the panels and rust
