Vinnys Ventures
Spurry
There is a specific shaped steel blade for the Evolution saw. I had one to chop up the old 3mm steel oil tank.
Worked OK to cut out some 6mm steel plate yesterday.
Spurry
No it's not, the tips are a differrent shape to ones I have. Your pic looks like a wood cutting blade but the actual tips have been altered in cross section.
Here's a couple of pix of mine, but I have to admit the saw is not the latest version.
That’s one for stainless steel bud . The dark blue ones are steel . I’ve not seen one the same as spurrys one
Spurry’s one is the ‘basic’ one, more for cutting wood with nails etc, or small amounts of steel.
The blue one has the same teeth (negative rake) but more of them. For steel
Green is aluminium.
There are (or used to be) Chinese versions available. I have stocks of the 254mm version which fits my Makita battery saw. Evoloution blades are pretty pricey.
I looked into that but was advised againstit because for cold cut it needs to travel at a different speed or the filings stick to the panels and rust
surely the ridge is going to be flashed so no exposure to the wet stuff ?
