'bout what we had last time Jim ..... started coming down here again ... but a lot of what was here this morning has gone mostly3" here
2.00pm
10.30 am
looks like ashbrook hire tractorsMost likely your usual 'Young Farmers', with Daddy's tractor and Daddy's diesel, doing their bit for the community. I mean, for the Instagram likes
used to have a piece off 400 x 20 with two bits of 160 x 80 RHS welded to the back of it, 6ft wide, like that .. could clear the yard pretty quick with the hyster H80CView attachment 21323
Best 300 quid I ever spent. Gritter drivers must be self isolating I reckon! Roads are fun here .
Tidy, nearly made one myself but used to know lad that sold these and 300 ish seemed silly, ordered fat rubber strip for bottom finally after "been meaning to" for a few years!used to have a piece off 400 x 20 with two bits of 160 x 80 RHS welded to the back of it, 6ft wide, like that .. could clear the yard pretty quick with the hyster H80C
biggest problem with a lot of snow was you ran out of places to push it to pretty quick, even well compacted, so a 10' x 5' x 12mm plate pushed under the heaps enabled me to move it elsewhere .... tip the plate off and over, then pick the plate again and do the next heap ...... a bucket to go on the forks'd've been handy, but for once or twice a year, wasn't worth the faff of knocking up . ....... had a huge pile in the middle of the yard one year ... was there for months.
They maybe didn't realise they weren't spreading any grit (and I'm not joking it happens)We had 3”, not much in the grand scheme of things. At 11 last night the plough came through here after everything had frozen solid, so it just bounced over the ice and didn’t clear a thing. They didn’t put any grit down so this morning I drove 6 miles without touching tarmac. Then I had two hours snow clearing on a 259 CTL.
The trick is to leave your window down slightly, so you can here it bouncing off cars (it was mentioned on a course once as a way to check)They maybe didn't realise they weren't spreading any grit (and I'm not joking it happens)
They still got to know how to use them though and thats the problem.Must be ancient gritters
All the ones round here are unbelievably complicated gps controlled the lot lot and soon let the driver know if he isn't gritting something he is meant to
Also cameras in the back and facing the spreader plate on a lot of them
