Mogmans creations πŸ€”
Davedb
Tidy job did you wire it to one battery to get your 12v then? Or use a voltage reducer
Be honest you're gonna fold that bird nest up stuff it in the box put lid on and forget about it πŸ˜†
No will give it a hair cut in the morningπŸ‘ just left them long till I knew it would work while swapping wires aroundπŸ€”
Got a large battery in the original box that works the cab and a smaller one behind the counter weight that boosts to 24v
lets see if it pulls the cab battery downπŸ€”
also had a thought about cab heatingπŸ€” I may put a cooler on off an auto box in place of the heater matrix and bleed a bit of hydraulic oil through it on the return side of the spoolsπŸ˜‰
Had a good day today (not broken anythingπŸ˜‚πŸ˜‚)
Had a measure up for a β€˜new’ window and this animal yelded one an inch bigger than the original
so after getting the old one out and cleaned up, and a few measurements and careful cuts with the grinder got this installed, feck it’s even tinted
looks like is was made for it on the inside
gave the spaghetti wiring a hair cut to see what was whatπŸ‘ and a general tidy up around the engine bay
a couple of pictures of the dash lights,
ignition on
engine running πŸ˜‰
still got to fit the air filter as the engine inlet is bigger and in a slightly different place and make the body panels to fill the gap that I created by cutting the machine in halfπŸ˜‚ the exhaust is now where it was originally under the counter weightπŸ‘
but it’s all working as it shouldπŸ˜‰ did have a fuel leak😒 was a perished over spill pipe on an injector😯 was a bugger to get at but sortedπŸ˜‰ been scratching and scraping for a few hours this afternoon in the yard and never missed a beat
Ran it over the weight bridge too, may of gained a few pounds😳 but still a midiπŸ˜‚πŸ˜‚
so after getting the old one out and cleaned up, and a few measurements and careful cuts with the grinder got this installed, feck it’s even tintedView attachment 22671
gave the spaghetti wiring a hair cut to see what was whatπŸ‘ and a general tidy up around the engine bayView attachment 22672
ignition on
engine running πŸ˜‰
What's that swissport tug like? Always fancied a spin in one...sure you've got a 747 tucked away in there..πŸ€ͺ
I can’t wait to see what breed of thing is going to be the donor for the glass.....
ignition on
engine running πŸ˜‰
Well....feck me sideways and call me Susan, you haven’t disappointed there at all! That window is inspired!
Sterling work as ever πŸ˜ŽπŸ‘
ignition on
engine running πŸ˜‰
At that weight you can still take part in the 5ton challenge!!
If not Id bet good money that there will be an eberspecher heater in that yard somewhere !
Davedb
ignition on
engine running πŸ˜‰
Just leave me the engine out of that didn’t need window anyway πŸ˜‚ cracking job
I swear your the type could fall in the dung heap and find a tennerπŸ™ˆπŸ€£πŸ€£πŸ€£
only a tenner !! :oops: ........ more like a fifty or a winning lottery ticket for the euromillions
Rob65
Exactly my thought.
With the extra weight on the back end twin hoist cylinders might be required to allow it to give its full potential πŸ˜€πŸ˜€πŸ˜€
