No lights, radio, wipers or fan on during the drive home for you.
And don’t try and charge your phone either!!
Welcome to my world..So ranger is in getting some bits sorted and have been given an e transit for the courtesy van.
125 miles to a full charge, have driven to Tamworth and will be a good 30 miles short of charge, so currently sat in mcds whiles it's charging.
Was near enough empty on the way up and will have not a great deal of weight on the way back.
I don't think they move when charging, although didn't try it. Car park was tiny, stupid bollard near the charge point meant having to hang over the bay in front to be able to open the door, another van pulled in front but stuck out a fair way as the charge point sticks out the front, unlike all the other electric motors I seen that seem to have the points on the side like normal filler capsI really want to see someone with a big Genny in the back of one of these and the plug snaking around and charging whilst they drive...be a good bit of craic. Guessing it won't allow it unless stationary?
I assume it'll be flat when they come to collect itYeah that's pretty much what I came up with when found out the range this morning. Was hoping it was just an average or loaded figure but nope, that's a best case, running empty scenario.
Currently still waiting and seems to have added around 30 miles of charge so still got a bit of a wait as it's tight on the dash Vs the sat nav distance
Just called them to check and my ranger isn't done or by the sounds of it even started so, got it for another day which is a shitter as not only can I not charge it at the house but was meant to be out in the 3t. To be fair the weather was apparently crap today so at least will have a day to dry out. So change of plans and looks like will have to go sit at a charger for a while at some pointI assume it'll be flat when they come to collect it![]()
I'd be telling them you're sending them a bill for transport for your 3Tonner, as they've not supplied you with a like for like vehicle and they're disrupting your business operations, with the consequential losses, their liability .... might promote enthusiasm to stick to their given schedule for your truckJust called them to check and my ranger isn't done or by the sounds of it even started so, got it for another day which is a shitter as not only can I not charge it at the house but was meant to be out in the 3t. To be fair the weather was apparently crap today so at least will have a day to dry out. So change of plans and looks like will have to go sit at a charger for a while at some point
None of there courtesy vehicles have towbars, last time I had a msrt transit custom, would rather use there motors as little as possible the msrt was £800 excess for any damage and this electric one is £500 and that's for all damage bar stone chips.I'd be telling them you're sending them a bill for transport for your 3Tonner, as they've not supplied you with a like for like vehicle and they're disrupting your business operations, with the consequential losses, their liability .... might promote enthusiasm to stick to their given schedule for your truck![]()
An utter joke.View attachment 59676
This is typical MC Don charger. .85p a KW. It's .25p at my home and that's a standard rate,not an ev rate deal. This s**t is so unregulated, even motorway fuel isn't nearly 4x the average..
Same charger I used earlier, 85p/kWh seems to be what the 150kwh chargers are priced at yet from the one earlier and the one just now (no 3 pin plug charger with the van) they seem to barely pump out 40kwh so are charging the 150 rate premium while delivering less than a third of the advertised rate.View attachment 59676
Mazda already doing the same with the mx30 r-evcue the Nissan E-power
Does the app work on estimated miles added? Is the miles added far off your actual miles?View attachment 59678
This is my home charging for April for comparison,at 25p per kWh.
The problem our company seems is when the home chargers breakdown we wait up to a month for a repair.Ive spoken to quite a few colleagues with constant problems.As our company car private use charge is quite generous,it's based on a assumption that most charges are at home I.T.R.O. 15-25p per unit.
If we do a month on external chargers at 85p upwards,they will eventually look to up the charges to us. A bit of a problem brewing I think..
It's quite accurate TBF. That's my worry about pricing,the difference in home v away.Does the app work on estimated miles added? Is the miles added far off your actual miles?
Charging prices are mental 308.62kwh is £77.16 at 25p/kWh Vs £262.33 at 85p/kWh![]()
So a train thencue the Nissan E-power
