yanmar b03 scopy restoration
Y
yanmarb03
That panelwork is amazing though. Tip for priming bare metal for you, use a 2k etch primer. I always use Tetrosyl, but others are available, it will bond to the metal like you would not believe.
I have put them in just some red oxide at the moment to protect them it's going to be awhile before I'm ready to get them on and mounted
Y
yanmarb03
Can anyone recommend a hydraulics company need a full replacement for these
More to add finally top coated hopefully get some of it back together soon
if I brought a piece of anything machine-wise into our lounge and parked it on the carpet SWMBO'd go bat sh1t , freshly painted or not ... you must have an understanding wife/she's out/you live on your own .. delete as appropriate :giggle::giggle:
(did once get away with Josh's bike in the conservatory) :giggle: .. got pix but can't find them ATM
  • Haha
Reactions: maz
Y
yanmarb03
My other half is very good if you saw the spare room it's full of parts for the digger all the new panels are in there all the labeled boxes of nuts and bolts for it are fuel tank is I'll try and find the photo of when I serviced my forks on my mountain bike in there
I had a handmade tig welded exhaust(primary designs for those interested) as my table centre piece when I lived on my own.. when the wife to be moved in it was no more… 😟
Y
yanmarb03
As I said I am very lucky 🤣🤣🤣 Mt other half is a nurse and is not at home much
😒 all the time it’s full of B03 it’s not available for the B03 owner!
😎 seen some of their manifolds, work of art!
Yep, I had a manifold and full exhaust on a mk1 focus Rs, should of never sold any of it! Stunning things, thus why it lived on the dining room table until I fit it 😉
Y
yanmarb03
Had the afternoon to myself more progress all the undercarriage back together expect a few fat washers I'm waiting on tracks on base bolted back on to the top now to try and get the engine started.
If anyone has any information on these engines please come forward I can bearly find any info on them on Google it's a yanmar own brand petrol engine
Y
yanmarb03
UPDATE
Mounted the engine very weird starter it has a ni-cad battery separate to the main battery that has to be charged so the starter motor to kick in obviously that battery had died ended up by passing that and and great news it starts and runs unfortunately I'm now moving house so it has all been packed up ready to move
UPDATE
presumably the NiCad operates the solenoid? can you not use the main battery to engage it with .... if it's a lower voltage, could always put a HD wire wound resistor in series, to drop the voltage if needed? (y)
