Mark
I’ve still some terex’s parts laying about the workshop if there any good to you, axle dif seals, hub seals, wheel bearings, brake clutch plates.Not 1 but 2 ADTs in the workshop
Mark can you PM me your number, I’ve been using Mick over at MJP and he may be interested in buying your partsI’ve still some terex’s parts laying about the workshop if there any good to you, axle dif seals, hub seals, wheel bearings, brake clutch plates.
tap 'em out to BSP ... Metric from new IIRCKinshofer grab that taken a beating and ripped the thread out of valve block
is that a Yank machine Gus ?? Linkbelt perhaps?Call out down to Newcastle to get this crane back up and running so they can continue to train there delegates
Looks Chinese zoomlion maybe?is that a Yank machine Gus ?? Linkbelt perhaps?
looks to have lots of panel work added ? I've seen one before with the curved screens but damned if I can recall what it wasLooks Chinese zoomlion maybe?
Already BSP ports with metric on other endtap 'em out to BSP ... Metric from new IIRC
Yea a zoomlion 2007 586 hours in it apparentlyLooks Chinese zoomlion maybe?
shorten up some BSPT / BSP adapters and dog 'em in there on the shortened taper?Already BSP ports with metric on other end
Tried that but due to being an Ali block it literally pulled all the threads clean outshorten up some BSPT / BSP adapters and dog 'em in there on the shortened taper?
