Davedb
Tidy job did you wire it to one battery to get your 12v then? Or use a voltage reducer
No will give it a hair cut in the morningBe honest you're gonna fold that bird nest up stuff it in the box put lid on and forget about it![]()
Got a large battery in the original box that works the cab and a smaller one behind the counter weight that boosts to 24vTidy job did you wire it to one battery to get your 12v then? Or use a voltage reducer
they're closer to Β£2.5K newTheyβre like 1200-2000 on eBay how do you do it!!! Haha
Β£10,000 no VAT Iβll deliver it tooBrilliant. Is it for sale now![]()
What's that swissport tug like? Always fancied a spin in one...sure you've got a 747 tucked away in there..Had a good day today (not broken anything)
Had a measure up for a βnewβ window and this animal yelded one an inch bigger than the original
so after getting the old one out and cleaned up, and a few measurements and careful cuts with the grinder got this installed, feck itβs even tintedView attachment 22671
looks like is was made for it on the inside
gave the spaghetti wiring a hair cut to see what was whatand a general tidy up around the engine bayView attachment 22672
a couple of pictures of the dash lights,
ignition on
engine running
still got to fit the air filter as the engine inlet is bigger and in a slightly different place and make the body panels to fill the gap that I created by cutting the machine in halfthe exhaust is now where it was originally under the counter weight
but itβs all working as it shoulddid have a fuel leak
was a perished over spill pipe on an injector
was a bugger to get at but sorted
been scratching and scraping for a few hours this afternoon in the yard and never missed a beat
Ran it over the weight bridge too, may of gained a few poundsbut still a midi
Might struggle with the low loader backing up your driveYou know where i live![]()
Youβve got a digger on the back for βwideningβ purposes, Iβm confident youβll make it fit (but Iβd ask for cash in advance just in case)...Might struggle with the low loader backing up your drive![]()
I canβt wait to see what breed of thing is going to be the donor for the glass.....
Well....feck me sideways and call me Susan, you havenβt disappointed there at all! That window is inspired!Had a good day today (not broken anything)
ignition on
engine running
At that weight you can still take part in the 5ton challenge!!Had a good day today (not broken anything)
ignition on
engine running
Bring it onAt that weight you can still take part in the 5ton challenge!!
If not Id bet good money that there will be an eberspecher heater in that yard somewhere !Got a large battery in the original box that works the cab and a smaller one behind the counter weight that boosts to 24v
lets see if it pulls the cab battery down
also had a thought about cab heatingI may put a cooler on off an auto box in place of the heater matrix and bleed a bit of hydraulic oil through it on the return side of the spools
Just leave me the engine out of that didnβt need window anywayHad a good day today (not broken anything)
ignition on
engine running
only a tenner !!I swear your the type could fall in the dung heap and find a tenner![]()
Exactly my thought.At that weight you can still take part in the 5ton challenge!!
