MacAulay Plant Services
wee_gus
wee_gus
Hydraulic pump seals replaced for farmer ready for hay turning, couple of hoses replaced on loader also
wee_gus
wee_gus
Undercarriage replacement on case CX130, chains and sprockets
1 engineer 7 hours, decent going
wee_gus
wee_gus
Call came in at 1630 yesterday and on site this morning by 0800 with replacement pin, and refitted snapped track onto timber harvester
That was the initial theory but on measurements it’s running true, there’s only 2
Of these in Scotland and they both have undercarriage issue
twisted then ?? .... in the horizontal plain ;) .. is the wear identical on both .... build jig issue ?????
I think what we are saying is, if you just work a bit harder you'll get more jobs done and more pictures up to keep us entertained 😁
wee_gus
wee_gus
I couldn’t see the other one but apparently not identical, they have only ever sold 7 ECR88D with steel tracks in Uk & Eire. We have rotated the idlers around just now and will check again in 500 & 1000 hours to see what’s going on
well summat is deffo out of line to do that to the front idler :oops: :oops:
I may be wrong here but are steel tracks that much worse for sprocket and idler wear than rubber. Do rubber tracked Volvo 8t not suffer from higher wear than other makes?
wee_gus
wee_gus
I’m not 100% sure. All my customers machines are on steel. So don’t do a lot with rubber tracks.
I
wee_gus
wee_gus
cat 320E in for undercarriage replacement, Hose replacements, teeth replacement, LOLER, QH repairs, and new beacons wired into shut off lever.
wee_gus
wee_gus
Flow and pressure checking of machine.
Wire in shear harness.
Diagnose damaged valve block leaking internally
wee_gus
wee_gus
Undercarriage replacement down in Chesterfield
wee_gus
wee_gus
Undercarriage replacement in Preston, she was a little bugger as track pads had been run slack
wee_gus
wee_gus
Last one of the week, undercarriage replacement in Perth
wee_gus
wee_gus
Even we have bother 😂🤮
