Cheers - so its plummed off your dual flow hammer line - can it share the oil and tilt and rotate at the same time ? and potentially that unit would be plug and play onto a hi spec machine with 2 x prop rollers and leave your old joysticks behind or would that need to be a 4 hose unit ?
Runs off the twin service. It will tilt and rotate at the same time. As for plug and play on a hi spec.....that is above my pay grade! I will take some pics tomorrow
sadly no .... Shaun's control is two cetop 3 two way valves controlling the prop flow from his pedal feed ...
the cetops direct the flow to either/or/and tilt & rotate... in either direction separately or simultaneously ...
the speed at which they operate is controlled by his foot ...
down side is you cannot vary the speed between operations - i.e. fast rotate and slow tilt or any combination ... in reality if you are rotating and engage tilt whilst doing so, rotate will slow as the tilt takes flow ...
you can either increase flow with the trotter or leave it ... letting go of tilt will then increase rotate, back to where it was or increase tilt speed if rotate is dis-engaged.
trick with the pedal and button set up is to always select a function with the relevant button, before engaging the hoof, other wise you load/dead end the prop circuit AND the function comes in with a bang if you engage hoof before the button ... you get used to it ... it's how I built mine
for a two roller set up it could probably be re-plumbed for 4 pipes, but for full house DC2 control, you'd need to have prop solenoids in the unit an' a whole lot more techtrickery
