R.Sanders Plant
K
Komatsu
lovely units, but a hell of a price, from memory Ollie
Just been speaking to Shaun, the unit, in the picture can be got from Rototilt for about £450, which I think is very reasonably for what it is, think I’m right in saying that they’ll connect under pressure as well.
That's not as bad.
K
Komatsu
That's not as bad.
That’s what I thought, and I’m sure there’s always a deal to be done, he will hopefully be signing up to the forum over Christmas so sure he’ll be able to answer any questions that need answering.🙂
They one that Graham linked to has twice as many ports though (2x 1/2inch and 2x 3/4 inch). I’d imagine the cheaper unit is only 2x 1/2 inch possibly?
K
Komatsu
T whiting
T whiting
What would you do for other attachments if you had one of these setups? T flat faces into the lines before the fancy block?
summat like this I'd guess would give you 'access' Thomas
I think for the price Gra, that there good value for money?, £450 is cheap enough for something like that and something that you would keep with the tilty for a long time.
could've sworn i posted a reply to this Oll ??? :confused::confused::unsure: ....
I agree .. they are reasonable VFM .... but you'd wanna keep it with the tilty when it got swapped, for sure
T whiting
T whiting
Yes I seem to have enough issues with ½¾ and inch connectors mounted one way or the other at the moment without introducing quick change blocks it's a neat idea though
Yes Ollie spot on. IMHO a good cheaper alternative to the likes of EC Oil, Oilquick etc. Also keeps the s**t out of the connectors as there out of the way on the boom.
450A has been shunting loads out. Can knock a 8 legger out in 4 buckets 😂 And it's paid for, f**k the finance the 50 year old machine works.
Crusher is nearing testing phases.
Benford dumper still has issues after the head gasket being done :( So out it comes :cry:
looks a LOT drier with you than it is here Rory .... you'd be dragging that truck in and out here
That was Tuesday..... And done on a tip we have setup.... Lorries are sat on muck that was put down last summer with roller and compacted to f**k!
Muck that has come in is good but a little damp. Not going again before mid January so hopefully will get a good bit of weather, smack it back down and then go again!
1000% drier than here mate water standing everywhere :( :oops:
Jimoz
Must be well compacted that they're sinking over the path on access to my job atm. Not sure who's problem it is. Mine, hauliers or council. When I've created accesses I've had to do them to council spec and no problem with 8 leggers over. This one was already done when I got here
Some more shite collected this weekend. Sykes pump was too cheap to miss. Seems Seized but should live again.
Jaw bucket is a JCB, but also has a Wain Roy Plate :unsure: never done much work by the looks. 18" and should fit the taki's a treat
