I'm struggling to make sense of the diagram too. My guess is 7 is a neutral interlock. From there, the wire seems to go to 73 (ignition switch?).
The two wires that T-off - one goes to 73 and the other goes to relay 71.
Vin, how are 7, 71 and 73 described in the manual?
I spent close to 2 hrs trying to suss that dia last night and it does not make sense in a few areas ..
7 is a safety cut out sw. on crank circuit (clutch pedal possibly)
71 is ignition relay (doesn't control solenoid but all other ancillaries -heater/wipers/etc.)
73 is ign sw. but I am wondering if the 5 pin diagram I put up a few pages back is the right one for the application? the sequencing on that doesn't look to be right for the way this dia. operates
Vin - can you put up the wiring diagram for the new switch together with its sequence of operation (like the 5 pin-er I put up a few pages back )
it is one weird sequence of events when turning the key
there's also one item in the dia. that's not numbered
the item below 13, on a green wire ?? it's in parallel with the heater plugs - bulb perhaps, but wrong symbol - perhaps one of those 'glowy' things you often see in a traccy dash - chrome with holes in it and a coil that glows behind it - indicator they're energised?????
14 " thermostart"
15 is air cleaner vac. sw.
I am damned if I can see how the ign sw. gets a feed from the battery (6) though - only thing connected to the +ve pole is the alternator's feed ????
and I am convinced that the wire below would provide a constant feed to the starter solenoid
