I’ve now got power back in the dash after sorting out some wiring bodges !
I’m still trying to resolve issues just now . Can anyone tell me what each terminal does on the ignition relay ?
What I think is correct so far is
black (15) is to earth
Green (86) 12v supply from fuse 8 live when ignition is on
Brown (30) this one confuses me , the diagram seems to show that it joins onto white/yellow from ignition position 5 to starter solenoid . I need some clarification on this ? Seems strange that a 12v ignition on supply connects with 12v supply that tells the solenoid to pull in the starter ??
White (87) 12v goes through fuse 4 then changes to green and goes to dash bulbs inc alternator light
White / yellow (87) goes through fuse 15 and supplies 12v to cab heater
85 and 86 are the solenoid coil wires in the relay Vin
85 needs to go to an earth -
86 needs a live supply from the crank position on the switch - terminal 3
30 needs a constant live supply from the main starter pole, fed directly from the battery -
an/one 87 needs to feed the starter's solenoid 6mm terminal -
that will give you a crank and start when the ign switch is turned to crank -
there is no 15 on your new relay.
you need to have a constant live
to terminal 1 on the ign switch (fed from the main pole on the starter again - as 30 above)
from terminal 2 on the ign switch you need a feed to one side of the charge light bulb on the dash (this becomes live on the first turn of the key)
terminal 5 supplies power to your heater plugs (or the heater plug relay if fitted) (this becomes live when you turn the key to heat position on the first detented key position)
terminal 3 feeds power to your pin 86 on the ign relay to energise the starter solenoid in the detented crank position.
terminal 4 supplies power to all your other aux/ancilliary circuits (usually through/via the fuse box distributor) - wipers, heater, indicators, radio, whatever, etc., when the ign key returns to its position 1 -- i.e. the run position
in the
running position 1, on the ign switch,
without the engine having been started the other side of your charge light earths through the alternator's little (6mm) terminal - once running that terminal becomes live and the bulb goes out as it no longer has an earth - the 10mm terminal(s) on the alternator require at least one connection/wire to feed the charge from there, to the main pole on the starter and thence to the battery to feed charge into it
and that's your basic start/charge circuit
