Rob65
I think someone has got either their units or decimal point confused. In the small print of the spec for that it says 400w. That’s about half a horsepower. Which looks a bit more plausibleperusing the various VFD offerings on Fleabay last night I found a few interesting items Dave @Routy56
can't quite see how this is soooo cheap, sooo small and run 4hp? might risk one to try though - finding a suitable enclosure may prove interesting as this is obviously intended for panel mounting, which is good from the point of view of wiring security and OK if you have a decent enclosure to fit it into already - 's gonna need air circulation - smart little unit though
been looking for a BIG one for a while - there's a 10hp motor on the lathe - and not had a look yet to see if the motor's suitable - whether I'd wanna chance nigh on 290 quid is another matter, but looks to be the same breed as those I already have, which have performed well (so far) - couple of years in with the one - intermittent usage admittedly - but does what it's supposed to every time I go to it -- will have to get my head into the back of the Harrison and firstly see if it's suitable ... then give it some serious thought
the convenience of just being able to switch 'em on is nice - be interesting to know just what their power draw is though, too
- not gonna run 7.5Kw off a 13A, 3pin -- and'd make the meter sit up a bit
Variable Frequency Drive 220V To 380V 3‑Phase Motor Speed Controller 11KW 15HP☯ | eBay UK
Equipped with Motor: 11KW 15HP. Rated Power: 11kW. Feature: 1. The frequency converter is a step-up type, civil 220V to industrial 380V, wiring is simple and convenient. This product is a non‑standard step‑up inverter, which needs to be customized.www.ebay.co.uk
