Mogmans creations 🤔
Today’s shenanigans
found a crack in the crane😳😳
it’s on this 👆linkage that opens out the telescopic arm
cracked just off the weld on both sides (still plenty of meat left but🤔)
IMG_1409.jpeg.
so gouged it out with the plasma gouging torch (first time I’ve used it 👍)
then die ground it back to clean material
and poured a bit of liquid steel in💪
And because I’ll be having a few days off😢 made a start on the manual pull out extension
had the steel folded to a pattern I’d made
then welded the two halves together
welded an end plate to one end and drilled the holes for the pin to hold it closed in or exten, got some thick walled tube that I will weld into the holes so the pin can aline easier
next job is some 1” plate on edge welded top to bottom that the hook can hang from (after the guy in the red coat has been😉)
Was a Manual pull out an optional extra for your crane? I seem to remember seeing something about it when I’ve checked out your crane specs in the past.
Yes can get two manual pull outs🤔 but very expensive from cormach 😳
was told that the first extension without the ram on top was £10k😳😳
feck knows how they get there prices
  • Quote_QC2005.PDF
Today’s shenanigans
View attachment 55431.
was that a true crack in the parent material or a cold lap Mog?
what spec. material is the Cormack component fab.ed out of Mog? ... most of these loader cranes use some pretty exotic HT grades
Canal Navvy
Canal Navvy
obviously only have the pic to go on, but looked suspiciously like a cold lap on my screen :unsure:
Did to me too.
Also reminded me that I really ought to persevere with plasma gouging as the good old arc/air does risk adding unwanted carbon.
Well I gouged out to where the crack stopped (cold joint I think)
and the ‘carpentry’ is a bracket that holds the pullies (will take a picture) mine got bent in a previous life but I straightened it out after they sent the quote😳
as for the metal will be some good stuff💪 but my extension will only be used for the hoist lifting air con units so max 600 kgs but will test to 1500 kgs it’s 8mm folded and bloody heavy (too much for me to lift😢) I think I’ll be on the right side💪
sounds all good then Paul ;):giggle:(y)
taking the p*ss really :rolleyes:
This is all you get for over £900😳
with out the pins😳😳
But on another note 😉
got these big lumps in primer👆
then today got some colour on it too
now only the tele part to do👍
hopefully will make a start building it up on Monday to make room for the tele part in the shed for paint🤔
