Mogmans creations ๐Ÿค”
what circuit you going to use it on Mog ... the VA ? .. assume it's going on the duck?
No going on the tracked machine, going to use the bucket circuit with a couple of taps to divert the oil from the machine ram to the JCB bucket ram, even though it has two double acting services going down the dipper will be easier to work with๐Ÿ‘
So basically set the original bucket ram where you want the extension to be then move the taps over to operate the new one? Simple is the best way ๐Ÿ‘Œ๐Ÿป
Well after making the extension arm for the big un the komogsu wanted one๐Ÿคทโ€โ™‚๏ธ
So adapted one I had off a 3 tonner I scrapped
Got another 5โ€™ of reach
And folds up nice and tight thank god for tape measures and angle finders๐Ÿ‘
New project on the horizon๐Ÿค”๐Ÿ‘
found a stillage that will make a sound base for it and make it easier to move around
then got a hopper 2m high X 2.4m long X 1.5m, from the โ€™yardโ€™๐Ÿ˜‰ cut it down a bit so I can get a tote bag in nicely
got to weld the box section back around the top to make it strong
tbc๐Ÿ˜‰
Itโ€™s alive๐Ÿ‘๐Ÿ‘
just need to finish welding it up properly so it doesnโ€™t self destruct ๐Ÿ˜ณ๐Ÿ˜‚๐Ÿ˜‚
made to get the water out of silt๐Ÿ‘ I have a job of cleaning ceramic balls that come from a aluminium smelting plant (donโ€™t know what they do with them but have a lot of fragments of balls and grit mixed with them) so when I clean the trommel out (every 100 tons or so) I can separate the water (hopefully๐Ÿค”) and be able to dispose of the โ€˜dry wasteโ€™ to a recycling yard cheaply
think they get used for recirculating wheel wash water mostly ... save on massive quantities of water being needed
outferkin'standing Mog ... love it :love::love::cool::cool:(y)(y)
so when I clean the trommel out (every 100 tons or so) I can separate the water (hopefully๐Ÿค”) and be able to dispose of the โ€˜dry wasteโ€™ more easily by hiding it in a load of scrap without it running out all over the yardโ€ฆ
Fixed that for you!
may well be used to float on top of the melt pot, keep the heat in
Did a bit on the โ€˜cabโ€™ today๐Ÿ‘ got it in the work shop and started to look at the dash
decided the only way forward was to pull the dash out and have a proper sort out
now only need to find out what theses wires do๐Ÿ˜ณ๐Ÿค”
if all them white wires have numbers on 'em Mog, it's probably off the other end of these ... after I'd sorted the 'chaff' out ;) and extended a few - didn't have any white to suit - the chaff was a rainbow selection :LOL:
WP_20220725_17_20_35_Pro.jpg WP_20220725_19_44_56_Pro.jpg WP_20220729_17_46_12_Pro.jpg WP_20220729_19_16_50_Pro.jpg
cab mounts, mounted๐Ÿ‘๐Ÿ‘
just need to:-
sort clutch
do brakes
make a โ€™newโ€˜ accelerator pedal
get the spools to work from the cab
reconfigure both the oil and fuel tanks and fit them
get the gear leaver to change gears
relocate the hand brake (after Iโ€™ve free the cable and found a โ€˜newโ€™ handle)
fit the rear mud guards (after Iโ€™ve cut them down to size)
did I say itโ€™s a two seater cab๐Ÿ˜ณ so all the drivers controls need to be on the left hand side๐Ÿค”
so nearly there now๐Ÿ˜ณ๐Ÿ˜‚๐Ÿ˜‚
