Feral as Fk πΎ
Rear steer?
Rear steer?
Do you oxy it up back in the yard?
No got a big shear that will cut a lorry drive axle in two even with the half shaft inDo you oxy it up back in the yard?
When I first seen it I thought you had made an attachment to pick up one telehandler with another telehandlerMade this the other day
A superlift attachmentthe pipe at the top and the box in the bottom are full of lead and the sides are 20 mm plate weighs nearly 300kgs, held on by hooking onto the pegs welded to the chassis now my 2.5 tonne telehandler will lift 3 tonnes without the lock out messing things about
(only to be used by a competent person)
and what do you intend to hang off the top pipe Mog??Made this the other day
Who's your driver paul ?Made this the other day
Itβs a pipe because itβs what I had with a thick wall so when I poured the lead in it kept itβs shapeand what do you intend to hang off the top pipe Mog??... it's a pipe for a reason
going to weld a bar a bit lower down to hang my chains off but need to keep the middle part open because there is a door that covers the fuel tank![]()
Was going to say it looks like an original add on part!And we where all thinking it's masterfully designed to blend in to the machine and stop passing health and safety from suspecting a thing.
Tidy work.Itβs a pipe because itβs what I had with a thick wall so when I poured the lead in it kept itβs shape
Yeah saw your number plate at the last moment or I would of shown you how bright my main beam isWas going to say it looks like an original add on part!
Ps @Mogman that was me flashing today.. realised afterward how bright them headlights are![]()
Kin bright ... I've seen 'emYeah saw your number plate at the last moment or I would of shown you how bright my main beam is![]()
More reach, got a wide ditch to clear (4 meters wide but down 3 meters from where the machine can sit) plus itβs about 2-3 meters deepIs it depth or reach your after or both![]()
What you fishing for?More reach, got a wide ditch to clear (4 meters wide but down 3 meters from where the machine can sit) plus itβs about 2-3 meters deep![]()
tishWhat you fishing for?![]()
what circuit you going to use it on Mog ... the VA ? .. assume it's going on the duck?Finished it today with one of my buckets that a built over 25 years ago (I remember the job it was made for) and ordered the change over valves for the machine too
will give me 3m of extra reach![]()
