so they're not buried, per se, ??? ..... in a recess in a bank?I have fitted a couple of gas tanks and we had to leave one side open to let gas escape if there was a leak, this was under building control
Your got it three walls and lowest side openso they're not buried, per se, ??? ..... in a recess in a bank?
blast walls to 3 sides and free escape for leakage on the fourth side?
lorraregs for LPG storage
There is the key problem from "just" under 11kanybody off grid this might be a part solution but no good in winter my system producers very little from oct to feb
Solar & Battery demand is rising and so is the price. While stocks last, Suffolk residents can get 12 Solar Panels & 6.5kWh Growatt battery Fully Fitted from just £10,836 with no upfront costs![]()
Why choose World Of Solar?
Don't pay until your system is installed …![]()
See more
On a side note why can't we just fire up all the old coal power stations?
Nuclear can’t be turned on and off. Good for base load only unless everyone has storage…..wait…..are batteries and electric vehicles part of the long term solution?There is the key problem from "just" under 11k
How well do the panels work if not south facing?
Nuclear power giving all its downsides still takes some beating
be interesting to see their figures post October rise then
It's been trialed (using EV as storage) and probably works well for people who only drive 15min to go shopping etc. and don't need anything approaching a full charge.…..wait…..are batteries and electric vehicles part of the long term solution?
This is partly what’s driving the smart meter roll-out IMO, and in fairness makes a great deal of sense.It's been trialed (using EV as storage) and probably works well for people who only drive 15min to go shopping etc. and don't need anything approaching a full charge.
What I think you meant is 'will it be gov policy to use private cars as public storage'. - what gov wouldn't want to use a resource they don't have to pay for?
Vehicle-to-Grid (V2G): Everything you need to know
What is V2G? What does it mean that electric cars can balance the grid? Vehicle-to-grid technology has the power to transform the whole energy system.www.virta.global
True, but easy to overcome.(ie not selfishly unplugging their fully charged EVs, which lets be honest human nature would dictate happens more often than not)
No it doesn't! You can guarantee the export price at peak will be only a few pence more than the cheapest of the cheap 3am charging times.True, but easy to overcome.
If your export price is higher than your import price.
Then it becomes attractive to walk/bike/pt in case your car is making you money.
If it's going to cost you money to leave your car connected, then no one will - simple as that.No it doesn't! You can guarantee the export price at peak will be only a few pence more than the cheapest of the cheap 3am charging times.
Would barely cover the battery degradation, let alone be worth inconveniencing yourself for.
Smart meter,smart for whom?I would be most concerned that although they will promise only to take a certain amount from your battery so you always have enough for normal use they will have an over ride that will allow them to flatten the battery in times of emergency. Also it would be easy to legislate that anyone who has a battery vehicle has to leave it connected at home when not in use for the national good or to save the NHS, etc.
