ah right ... see the spring now ..... bypass relief ..... good idea ..... where'd you source that from and what sort of relief pressure does it open at?The valve is a bypass safety. Any restriction or flow beyond what can reasonably get through the rad gets bypassed. Save blowing the rad up!
I’m sure you could add a sensor/switch into a tee, or get a long barrel nut and drill a port in the side and tap it to suit a sensor/switch. Or get a test port tee, remove the test port and tap that out to suit?
yes .... could tap a sensor/switch into a 1" bsp tee, or as you say use a Stauf tee and take the Stauf out of it .. I've a few 1" M/F Stauf test fittings, that were ebay gifts, I could modify
