This is the field I need to manage . The green part at the top is my neighbours field and that’s what I want mine to look like ! There are springs that I am dealing with but a big issue is the dark areas are reed grass and it’s soaking in there . There is a stream though to the left of this grass for me to drain into . There is another dark patch at the top right of my field which is flooded from (I think) an overflow from another stream on the right and the reeds look lower than the stream . it could also be a spring . There is a really nice area out of picture above this wet area that is higher up and has some really nice trees in it . I’d like to be able to get through the wet area into this area .
I am working on getting the flooded areas dried up a bit but even after I have drains in it’ll still take ages to dry out .
Could I use a flail on a digger in these wet reedy areas ?
This field has been unmanaged for over 20 years so it’s needing some work to get it tidied up again .
