Captn Cetop, Why would he need a Sustainable Underground Drainage System?
Anyway, answer your bloody phone
I’ve been thinking this to Fred . Duck is getting a valve fitted so I can fit one to it I’m going to hire one for a bit to see how I get on with itits amazing just how little much will fit on a muckaway especially when its wet. Seems like after 6 buckets they are moaning about the weight. Not to mention the sign of any non-inert material or rocks etc and the rate goes up!
It's not far off making a screening bucket pay for itself ....
It's quite simple wet soil clags together in lumps so you can't screen it. The only way you could do anything with it would be to have a screener which chops/shreds it to some extent but then you wouldn't be screening out start you don't want in there just chopping it up and mixing it in.i think we will be forced down this route as finding tip sites for anything other than pristine soil means they have to drive a long ways which means £££
If we screened the stones/roots out first we could save £80 on an 8 wheeler.
Problem is all the screeners i looked at look like they work great with dry soil but not so great with the wet slop we get 99% of the time.
That’s why I want to hire one first to see what likei think we will be forced down this route as finding tip sites for anything other than pristine soil means they have to drive a long ways which means £££
The gyrostar and the lloyd bucket are near on identical other than belt drive on gyro vs chains on lloyd as far as i know. They all use the same plastic "stars" to do the screening from potato harvesters. Gyro dearer than lloyd spec for spec when i enquired although gyrostar tried to sell me a smaller bucket which would have made them cheaper slightly than lloyd under the proviso the one i wanted was too big for my machine (even though the vid on their own website showed the bucket i wanted working on a taki 290).that gyrostar that Alex ( @Op_Alx24/7 ) with the Mec had was very good and coped well with damper stuff .... no idea what it was like with real wet stuff though ?
Yeah lloyd rotastar and gyrostar two different makes of the same "star screening" bucket. I think lloyd would be the first tbh as I'm sure the family business was tattie harvesters and he modified a tattie harvester to screen some soil and adapted and engineered a bucket to do the job from that.this was Alex's .. Lloyd does ring a bell now you say it ... don't they make the gyrustar/rotastar?
Alex's was a Lloyd Nanostar, according to the pix ... came with a 3t pick up on it, but must've been a handful for a 3 tonner
View attachment 32377 View attachment 32378 View attachment 32380 View attachment 32381View attachment 32379
Swap itI have my soil deck screener, I do contemplate selling it and would go for a Lloyd bucket as being able to screen small quantities on some of my jobs would be very useful.
Chips remove heat from the cut. The stock itself also acts as a heatsink. Whether a specific operation requires pumped coolant or not depends upon a multitude of factors such as the duty cycle, cutting tool cost and lifespan. As for 'just' stopping stuff sticking to the blade- that's the point. Stops stuff sticking, thereby reduces friction, therefore reduces head build up below the level at which I consider coolant necessary compared to the cost/lifespan of the blade. Any choice of machining process for a given job will take into consideration all these factors as well as many more such as speed, feed rate and for bandsaws the tpi.What so the hotter the chips the cooler the cut? If the chips are hot the cutting is producing heat and needs cooling. All your wax stick or whatever you use coating is doing is stopping stuff sticking to the blade
I've got the Lloyd bucket 2nd to biggest one they doYeah lloyd rotastar and gyrostar two different makes of the same "star screening" bucket. I think lloyd would be the first tbh as I'm sure the family business was tattie harvesters and he modified a tattie harvester to screen some soil and adapted and engineered a bucket to do the job from that.
Yeah got mine direct after speaking to Matt him selfYou can deal with Matt Lloyd direct rather than paying a dealer through GyroStar. I don’t know him personally but one of my mates does. Says he has a very impressive set up and completely knows his stuff.
If you are only saving £80 per 8 wheeler I would have thought you would have trouble breaking even by the time you have paid for the screen, fuel on screen and loading machine, operators time, wear and tear, then still having to dispose of the rubbish you have screened out.i think we will be forced down this route as finding tip sites for anything other than pristine soil means they have to drive a long ways which means £££
one star .... Alex did tell me what spud lifter they're out of ... were circa 6 quid each back in '18 apparently, so a few bobs-worth in a bucket, but said they last well and stand a lot of abuseThe gyrostar and the lloyd bucket are near on identical other than belt drive on gyro vs chains on lloyd as far as i know. They all use the same plastic "stars" to do the screening from potato harvesters. Gyro dearer than lloyd spec for spec when i enquired although gyrostar tried to sell me a smaller bucket which would have made them cheaper slightly than lloyd under the proviso the one i wanted was too big for my machine (even though the vid on their own website showed the bucket i wanted working on a taki 290).
I thought they were a 40mm square?one star .... Alex did tell me what spud lifter they're out of ... were circa 6 quid each back in '18 apparently, so a few bobs-worth in a bucket, but said they last well and stand a lot of abuse
View attachment 32390 502 mm hole in the middle for a scale, IIRC
No, thinking about it a bit harder, 50mm or 2” sounds rightI thought they were a 40mm square?
