can just see a couple of them on the back of a mopedOne for Deliveroo?
I feel your pain! Pretty similar scenario everytime I break ground too. But digging rocks like that out fills me excitement- I get paid by the meter for my stone walling and the meters soon go up with rocks like thatrocks themselves are worth good money
Haha reminds me off the time I stuck these two in the back of my landy![]()
Been around along time they have! Fingers in many pies kinda guyThey’re from your way near slack hill way renolds sydnope only work for power lads got 5 x4cx pole masters must have been a foreigner
Pretty dubious on legality only doing power line work running on red and as agri
Stihl be quicker but hey if it works!Surprisingly good on the fastest speed for cutting up any old crap timber with nails. Unexpected use but happy days. View attachment 32374
It’s got an end stop and is much easier than bending over a pile of old posts. Just undo the motor stop switch a touch to keep it running, then feed with left hand and lift up with right hand to advance each cut. Cuts through an oak 5x3 in around four seconds, I’m happy with that for an easy life. Change to a really aggressive blade and you could probably shave another second off.Stihl be quicker but hey if it works!![]()
don't get the sawdust in the suds pump thoughSurprisingly good on the fastest speed for cutting up any old crap timber with nails. Unexpected use but happy days. View attachment 32374
I don’t use suds. Blades last just as long using a wax stick type lube and everything stays so much cleaner.don't get the sawdust in the suds pump though![]()
suds doesn't just lube Doob ..... it's called coolant for a reasonI don’t use suds. Blades last just as long using a wax stick type lube and everything stays so much cleaner.
Can see the need for coolant on a milling machine, but a slow speed bandsaw seems fine to me. At least, I never have any problems with the amount I cut.suds doesn't just lube Doob ..... it's called coolant for a reason![]()
Get a wood bladeIt’s got an end stop and is much easier than bending over a pile of old posts. Just undo the motor stop switch a touch to keep it running, then feed with left hand and lift up with right hand to advance each cut. Cuts through an oak 5x3 in around four seconds, I’m happy with that for an easy life. Change to a really aggressive blade and you could probably shave another second off.
plus it’ll cut straight through gate hinges, never mind the odd staple!
but not the talc sized stuff which'll gum up yer pump. ........... that blade gets pretty hot too Boyo ..... see how long you can hold your hand under the swarf coming off itCan see the need for coolant on a milling machine, but a slow speed bandsaw seems fine to me. At least, I never have any problems with the amount I cut.
Anyway, there’s a grill over the drain to stop metal filings going into the pump so I’m sure it’ll stop sawdust too![]()
As I understand it, the chips take the heat away from the cutting operation? Hence how you tell if your sfm is right on a lathe by the colour of the chips.but not the talc sized stuff which'll gum up yer pump. ........... that bade gets pretty hot too Boyo ..... see how long you can hold your hand under the swarf coming off it![]()
What so the hotter the chips the cooler the cut? If the chips are hot the cutting is producing heat and needs cooling. All your wax stick or whatever you use coating is doing is stopping stuff sticking to the bladeAs I understand it, the chips take the heat away from the cutting operation? Hence how you tell if your sfm is right on a lathe by the colour of the chips.
with TCT yes, but the blades'll be either carbon, bi-metals or full HSS (depending on how long yer arms are and how deep your pockets areAs I understand it, the chips take the heat away from the cutting operation? Hence how you tell if your sfm is right on a lathe by the colour of the chips.
Crap timber… in todays market that’s £400’s worth there alone!!Surprisingly good on the fastest speed for cutting up any old crap timber with nails. Unexpected use but happy days. View attachment 32374
