Canal Navvy
You’re cooking it for another 10mins right? It’s still oinking
That's the stage when they go fat side down round the sides of the pan to make room for the eggs
Need a few mins more for meAnyone like bacon just right....don't agree with grilling it to death...?
Did they request the steps In the lawn be interesting mowing itMore finishing up around this house the last week or so.
It’s like a cock-fighting arena!Did they request the steps In the lawn be interesting mowing it
Yes, they were on for a few fair minutes More to be fairNeed a few mins more for me
That! Is an interesting looking pad, bet that's a few quid![]()
Yes customers “design”, they have three full time gardeners so practicalities aren’t really a consideration .It’s actually all going to be planted up along each step eventually.Did they request the steps In the lawn be interesting mowing it
Just the gate house!That! Is an interesting looking pad, bet that's a few quid![]()
Bang on, just take the chill off it!!!Anyone like bacon just right....don't agree with grilling it to death...?
must be some ''small pump'' to give that sort of head -- that is some steep fieldFinished a job I've been on for last few days had to dig and lay a new 32mm water pipe to replace the old black one for a farm starting at the pump hose at the bottom of the hill along an old leat it still had 2 huge 3ph pumps connected to a 6" pipe that used to supply a tannery 5 miles away that are still in situ but long since redundant and they have a small pump and pressure vessel there for the farm did 300m of trench after the old leat it was straight up a steep field up across another field through the farm yard and up to the water tank
Unfortunately only took one of the steep field had to later that day go up it with the auger attached made for an interesting accent back down after once doing the strainer post holes as no go for a tractor with post banger the intermediate posts will be thin metal poles that wire clips too hammered in with a petrol driven post driver
Cable to right is nigh on level and hill wasn't an easy walk up
was about to say that is sandy soil -- then looked where you're basedFirst job with my own machine, Two n half days to complete with 8 cubic meters of dirt and grass removed and 28 stump holes dug for a backyard studio/living space.
We are all ruined with water filled supermarket bacon. Go get some proper dry cured fat bacon (usually more fat than lean) and fry it off till just before crispy.. then a slice of bread wiped around the pan is about the best treat you can getThat's the stage when they go fat side down round the sides of the pan to make room for the eggs![]()
I get as much as I can from our local butchers...not to coin the saying, but you can taste the difference and its not like its mega more expensive than the supermarkets. If only the masses realised the cheapness of supermarkets comes at a cost somewhere, as well as relying on the laziness of people visiting different shops for different things.We are all ruined with water filled supermarket bacon. Go get some proper dry cured fat bacon (usually more fat than lean) and fry it off till just before crispy.. then a slice of bread wiped around the pan is about the best treat you can get![]()
