E27 doing what she does best. She really is a superb machine for this kind of work, abs the Tigergrip is the best grab on the market IMHO.
Sorry to jump in here since it's not a "job" comment but I have been meaning to ask about quick hitches for the JCB 8018
I just bought. I have seen comments about spring hitches vs. a Harford pro-lock, with the pro-lock being more secure, less wear prone.
I see hurricane makes a manual S30 unit, how does it compare with a pro-lock.
Aiden @CPS :giggle:
Left hooker
Left hooker
Swapped tilty over to old machine as need Hitachi to do a few warranty bits to the new one (10 months old 😲now )
Fuel tank strap threaded end has broken probably overtighten when they installed the refueling pump
Wiper motor after working for some time starts howling probably winding part hitting outer housing
Also a vibration underneath cab from hydraulics vibrating a plate or panel sounds an electric wood plainer a chippy would use
Just glad have both machines as can't afford down time with work load
presumably you still had all the control systems, etc., still on board the old one Stu ???
Bought a pair of these, one for engine oil and one for hydraulic. They are simply brilliant. Pressurise them and dispense at your leisure.
I changed a gx390 oil in under two minutes today, using a vacuum extractor and then this.
I changed a gx390 oil in under two minutes today, using a vacuum extractor and then this. View attachment 32953View attachment 32953
Looks a great idea. The hydraulic filling on my loader is a two man job.
what vacuum extractor do you use?
