Left hooker
Left hooker
This pipe for the closed loop drainage off the back of the treatment tanks or just a normal pipe run away to location of drainage field šŸ¤”
You can’t beat a proper pipe laying bucket for that kind of job. Saves a fortune in stone. Got one here on 30mm pins, 125 centres if that’s any use? Distance a killer though I’m Sussex. View attachment 44350
I’ve got similar on 3 but don’t use on foul or top only on water mains or landdrains not enough room to get in trench do joints check falls etc
Constant running water, working on top of river bank, sceptic tank to the left, tree in front, pipes and French drains running alongside, it's been challenging!
Mini coffer dam to concrete the pump base
To do joints use a piece of blue rope under the pipe and hold both ends and lower it down. Then use a long handled graft to lever them together.
To check falls either a laser level or spirit level on a bit of string. And to level shingle a tarmac rake cut down to 120mm wide.
Can do the whole lot without climbing in and out of the trench and getting muddy.
Just a load of added faf
Priced at Ā£45/m for upto 1m deep and 110mm etc why add all that complication stone priced in already. I mainly use 12ā€ clay spade or 450mm smooth if going deeper or 2 pipes in run
Ad400 just overnight to keep them connected till we did next run following day to treatment plant
It never hurts to have some extra space in a trench when doing drainage, you can bugger around for hours shaving bits of the side of a trench etc when you can just dig abit wider and have room to move pipes around etc. Most of what I do is like Giles pictured above, nothing ever goes exactly to plan šŸ˜‚
It doesn't actually take any longer or more effort. Infact it's often quicker than scrabbling in and out of a muddy trench +keeps you clean
Just a different way of working.
Finished off drains job this am then bit of thinking Rd the problem getting old paving out the hole. My hoist wasn’t happy bunny, remote full of rusty water so hired this for Ā£80 for day worked a treat
maz
maz
Had 2 pigs to process on the farm yesterday. The 803 was a godsend, took the bucket off and attached a gambrel for lifting them up, in and out of the scalding tank, scraping hair off and then positioning lower for gutting and halfing, then trundled off to the cooler box. I dunno how anyone does it without a digger! Bloody versatile machines :) I’d post pics but don’t wanna ruin anyones fry up.
