Try thisHi Nigel,
thanks but the link ain't working![]()
Try thisHi Nigel,
That works - thanks
Please please ensure it's an ifor...That works - thanks
I'll obviously shop around before buying for both my trailers.
Until my son-in-law has arranged delivery of his company plant trailer I have no idea what it is.
But I'm guessing Ifor or Indespension. Will post photos of before, during and after for you boys to dribble over![]()
I'm with your school of thought on this one Dan -- that floor board is an insane amount and a stupeedo size ......... and that's just the start of the issuesIt’ll be well over £1000 in bits, never mind your time. I’d suggest sticking a cheap plywood floor in it and try and sell it ‘as-is’ for a grand on marketplace, and put the £2k thus saved/salvaged towards a new one personally.
Oh no what have I agreed to doIt’ll be well over £1000 in bits, never mind your time. I’d suggest sticking a cheap plywood floor in it and try and sell it ‘as-is’ for a grand on marketplace, and put the £2k thus saved/salvaged towards a new one personally.
Don’t you encourage himI'm with your school of thought on this one Dan -- that floor board is an insane amount and a stupeedo size ......... and that's just the start of the issues![]()
My guess is it has been towed with the hand brake on at some point or left parked with the brake on long enough for brake shoes to stick to the drums then towed. Brakes will then get hot causing brake linings to delaminate & the plastic wheel bearing centre caps fall out along with any grease that the wheel bearings might have had. So I agree with the above advice as they aren’t really that dear when new.Oh no what have I agreed to do![]()
Just read my own post & didn’t realise I was such a pessimistMy guess is it has been towed with the hand brake on at some point or left parked with the brake on long enough for brake shoes to stick to the drums then towed. Brakes will then get hot causing brake linings to delaminate & the plastic wheel bearing centre caps fall out along with any grease that the wheel bearings might have had. So I agree with the above advice as they aren’t really that dear when new.
All will be revealed when we strip the hubs downMy guess is it has been towed with the hand brake on at some point or left parked with the brake on long enough for brake shoes to stick to the drums then towed. Brakes will then get hot causing brake linings to delaminate & the plastic wheel bearing centre caps fall out along with any grease that the wheel bearings might have had. So I agree with the above advice as they aren’t really that dear when new.
Always look on the bright side of lifeJust read my own post & didn’t realise I was such a pessimist![]()
admittedly it does have a shiny new jockey wheelAlways look on the bright side of life![]()
aye but i've usually made a realistic appraisal of whether it's worth the costDon’t you encourage him
Says you Gra who fixes up stuff all the time![]()
more bloody money than sense paying that sort of extortionate amount for a bit of woodThey were expecting £600 odd on a new floor
more 'spensive bits ... and that's the 'cursory glance' 'summarily dismissed'But all I gave to do is make it safe to use. After washing it can see that it need 3 new tyres and brake cables have seized. So yeah it’s gonna be about £1000 in parts.
this bit certainly makes it look a far more attractive proposition, 'specially as you ain't paying the parts billAll I’ll need is a drink on top plus free use of the trailer and plant when required by me
Pfft .." little project "I’ll get my grandson to help as a little project![]()
Sikaflex - good sh1t and 'kin 'spensive - 'll fit in tidy with the expenditure listNow here’s a question- when I fit that nice new board, what should I use to seal the edges to the trailer sides?![]()
Cheap plywood? What planet are you getting that flown in from? I have decked one with kerouin before, personally I prefer planks to a solid board, you can replace odd planks if you go through.It’ll be well over £1000 in bits, never mind your time. I’d suggest sticking a cheap plywood floor in it and try and sell it ‘as-is’ for a grand on marketplace, and put the £2k thus saved/salvaged towards a new one personally.
18mm hardwood ply is less than £30 a sheet including vat here - two of those (or any old reclaimed crap of whatever thickness) would instantly add a few hundred quid to the trailer’s current value. Sort the bad earth, couple of bulbs, 4 plastic hubcaps if you want to push the boat out and that would sell easily to someone for £1k plus (probably more in reality!).Cheap plywood? What planet are you getting that flown in from? I have decked one with kerouin before, personally I prefer planks to a solid board, you can replace odd planks if you go through.
Price of keruing is madness. When I was buying some recently, one of the prices quoted was £77per meter on 140mm wide boards.Cheap plywood? What planet are you getting that flown in from? I have decked one with kerouin before, personally I prefer planks to a solid board, you can replace odd planks if you go through.
