Hi Mark, I’m looking for a laser for indoor electrical work if it has the ability to leave two 360 lines 90 degree apart e.g finding the center of a room ceiling.
Also be used for occasional outdoor use max 20m distance for foundation levels.
Do you have anything suitable
Hi,
Yes, a couple of options for you...
Please look at beam diagrams 7 and 8:
https://www.laser-level.co.uk/beam-diagrams.html
The links below each picture link to products which produce that beam diagram.
So the models you need to look at will be Fukuda FLE-444R, Spectra LT56, Fukuda FLE-444G, Spectra LT58G.
The two Fukuda lasers have a detector as standard and so can work outside out of the box.
The Spectra LT56 has the option to add a detector to the order but is not included as standard.
The LT58G currently has no option to work outside but a detector is launching late August which it will work with.
Top tip: If you plan to work outside, long range or in bright conditions, you will always need to use a laser detector with your laser level.
This applies to all makes and models and for both red & green lasers.
Hope this helps.
Best regards
Mark Roberts
Laser Levels Online
