Kubota kx 61-3. Buckets
Thomas7740
Thomas7740
Any use @diggerjones
This is my grading bucket for the E27 - it’s 1100mm across the cutting edge and the digger handles it fine. I ordered a 900 but they didn’t have them in stock when this was sent out - it was delivered with the option of swapping it for the 900 if I didn’t like it. Suffice to say it stayed here!
Come and have a scratch around with a few buckets if you’re passing fossil, there’s plenty of soil piles here you can tidy up!!!
memory failure James ..
could've sworn it was 6 degs to neutralize the pitch of the hitch under the tiltys and set the bottom level, side on, with the tilty vertical, L/R orientation ... sure i'd read it somewhere, but can't find it this morning? ..... Frank? @Bucket on wheels
Isn't the 5° for pallet forks and grading beams so they go round flat without having to tilt them?
think you have it there Thomas .... memory is not what it was :rolleyes: .... neutralizing the 6 deg angle the hitch sits at under a tilty .... that would fit nicely (y)
Do they all sit at a 6 degree angle then? Is that an S type standard?
Mine is dead square with the rotator, which is handy. But obviously not S type.
STBC James, but I believe they do ... Aiden @CPS ???
