£550 with teethHow much for a 750mm digging bucket for mine Aiden
It left early in the week, not sure what day but they did say 3 to 5 days to your addressNo sign yet Aiden
Thanks£550 with teeth![]()
Do not under any circumstances buy that, bought one for mine utter shite, the geometry was that bad we took the gas axe and welder too it after 3 days
Isn't the 5° for pallet forks and grading beams so they go round flat without having to tilt them?memory failure James ..
could've sworn it was 6 degs to neutralize the pitch of the hitch under the tiltys and set the bottom level, side on, with the tilty vertical, L/R orientation ... sure i'd read it somewhere, but can't find it this morning? ..... Frank? @Bucket on wheels
think you have it there Thomas .... memory is not what it wasIsn't the 5° for pallet forks and grading beams so they go round flat without having to tilt them?
Do they all sit at a 6 degree angle then? Is that an S type standard?think you have it there Thomas .... memory is not what it was.... neutralizing the 6 deg angle the hitch sits at under a tilty .... that would fit nicely
STBC James, but I believe they do ... Aiden @CPS ???Do they all sit at a 6 degree angle then? Is that an S type standard?
Mine is dead square with the rotator, which is handy. But obviously not S type.
Think it's 5 degrees on Rototilt, pretty sure the others are also.STBC James, but I believe they do ... Aiden @CPS ???
It's better than no hitch I suppose.Is this any good/ worth buyingwww.facebook.com
