davidgee
ill check tomorrow. i think it go's slowerWhat happens when you push this lever forward?
Off the top of my head order is accelerator, left track, lift (down for lift and up for lower), right track, low/high speed and tipill check tomorrow. i think it go's slower
Looking at the levers, it has a two speed lever, is it connected to the valve? It looks like its not connected but i just checked and the speed does change
not much. if you pull it back it lifts the skip. if you pull it forward it only works if you use the left track at the same time.What happens when you push this lever forward?
Did you mean left to right? Can you disconnect the two speed hoses, and blank the valve and hoses! Then let me know what you have?levers from right to left are
Throttle ( witch always slips when warm)
left track
lift skip
right track
2 speed lever
skip tip
yes sorry from left to right.Did you mean left to right? Can you disconnect the two speed hoses, and blank the valve and hoses! Then let me know what you have?
know where you're going with that QI think we have narrowed down the issue, get back to you shortly![]()
Seems to be an issue with how the two speed lever operates and the issues it causes when operated!know where you're going with that Q
thought it'd been decided it wasn't two speed???
very back - 2 pipes going to the pump
back line - Left track - skip up - right track - Nothing - skip tip - pipe to cooler
front line- left track - skip up - right track - nothing - skip tip , pipe to pump
I will do this on Friday / Saturday. do you think this will solve the tracking issue or just the down on the skip?Ok try this, remove the caps and fittings from the blank 2 speed valve, and fit the hoses and fitting from the lift valve, I see it has a 5th lever but no hoses!
Ok so the spool section we have changed the hoses over to has a blank spool in it from the factory! The original spool section is leaking into the track section (possibly an o ring) it’s a bit involved but as you are quite a dab hand at taking the block apart, follow the arrows! The old spool needs to go from the red to the yellow position, the green circled parts are check valves, in this position the valve will be fed by a different pump from the track motors and should not be affected, unless there is an internal crack!Hi, Morning! thanks again for your help with this.
last night i managed to change the hoses over, and tested it this morning. i had to strip the whole block out so i could change the blanks. anyways
the tacking is still jumpy and now the skip wont lift at all. Ive not tested it under weight
ok it seems putting it back together was harder then it looks.Ok so the spool section we have changed the hoses over to has a blank spool in it from the factory! The original spool section is leaking into the track section (possibly an o ring) it’s a bit involved but as you are quite a dab hand at taking the block apart, follow the arrows! The old spool needs to go from the red to the yellow position, the green circled parts are check valves, in this position the valve will be fed by a different pump from the track motors and should not be affected, unless there is an internal crack!View attachment 47251
