Two speed on the diagram? And it only operates one way?
on the leavers its :Two speed on the diagram? And it only operates one way?
Ok so only lift skip not working?on the leavers its :
left track
lift skip
right track
2 speed ( back 1 click is 1st, forward 1 click is 2nd)
tip skip
thats correctOk so only lift skip not working?
when operating the lift leaver no movement happens, but the engine noise changes.Ok so when operating the lift lever what happens? What we have done is from the start, we have gained a two speed valve but lost lift skip, the blank valve section is where skip lift should be! So again change the hoses from tip valve to lift valve, we know the tip valve works so it should then lift, and in theory tip won’t work. How long has the original issue been present in the dumper?
Now the lift is in the tiper position findings :when operating the lift leaver no movement happens, but the engine noise changes.
we have moved the lift valve from position 2, to position 4.
the problem has been there around 6 months that i know of and i have replaced both track moters.
ill go change the tip to the lift position now
Not really any help with this one but ...Now the lift is in the tiper position findings :
skip now lifts using the tip leaver
nothing happens on the lift leaver just a change in engine noise
tracks seem fine. not sure if they are in speed 1 or 2 though.
2 speed leaver . in speed 2 it tips the skip - speed 1 nothing.
i guess the 2 speed works like its either in normal or fast. like 1 setting
ive got it on a pdfNot really any help with this one but ...
Do you have a copy of the workshop manual or is it screen grabs?
Same it’s on line! So that valve section that doesn’t work on tip or lift is the issue! Needs stripping to find issue! The rams obviously work!ive got it on a pdf
ive Just been and stripped the block out and put it in the shed.Same it’s on line! So that valve section that doesn’t work on tip or lift is the issue! Needs stripping to find issue! The rams obviously work!
Anyone got a link for the pdf
i literally stripped it of everything and rebuilt it. i checked the washers for defects but they was fine. i replaced every washer. I wasn't clever enough to look for cracksSo the lift skip slice you have put back I think has an internal crack or damaged spool! Have you pulled the caps off this slice and examined the spool?
Morning Mick.On the ends of the lift valve you will find a cap and plate held on with hex head bolts, remove the cap and pull the spring and spool out!
Ok take a few pictures, according to the hydraulic diagram the tip spool and lift spool are the same, you could try changing them from block to block!Morning Mick.
Ill have to do this next weekend as i will have to strip the valve block back out again to do it.
i cant remember seeing any damage on the spool and i did look closely at them all. i just didn't look inside the block
Hi all. That time of the week again where i get to work on the dumper.Ok take a few pictures, according to the hydraulic diagram the tip spool and lift spool are the same, you could try changing them from block to block!
