I've been buying (very cheap) panels ranging from 5 to 15 years old. I test each one on arrival and so far none have tested lower than spec. (even one with a completely smashed glass)
There are two reasons for this:
- they don't degrade as fast as expected
- generally the warranty states that the panel won't be less than 80% of claimed capacity after 'x' number of years. The easiest way to achieve this is to under-spec the panel in the first place
As the price of grid power goes up, this becomes less and less true. Instead of trying to justify a PV install based on the feed in tariff, consider instead the electricity you are
NOT buying.
It is true though, for your average person the figures don't add up. The Government want us to go green, but have removed the incentive (of grants etc) and are instead forcing us to pay for it by hiking up fuel prices.
For your less than average person it can be made to work though as you're trying to prove. Going around the system by buying good used, doing some DIY, paying a mate to do the wiring etc, then yes it becomes viable. As I have a garage with a South facing roof i'm hoping to do the same.
I don't know if you knew, but there are some good FB pages on DIY solar, about 3 I think and one is UK based, I found out via that where to get a good deal on new panels.
Also broken panels can be fixed by coating them with clear casting resin and a UV additive, the output is lower, but not markedly.
We could be heating our workshops or houses on used oil, but the Government have taxed that too. So it's either non viable or illegal.
On a personal note:
When we moved here we got ourselves locked into a good deal on LPG. However the small print reads that if gas prices go up by X percent then the locked in price is void so it was a waste of time. They've got you by the balls every which way you turn. There is even a large standing charge on the gas tanks, so when I find an alternative to heat my house i'll still get hit with that.
I'm considering wind power as well as that will work where I live. We're halfway down a hill, a few years ago the house above me (which is right on top of the hill) put a large turbine up. It lasted a few weeks before being blown down, they didn't bother again.
