Maybe you should phone euroauctions and tell them you're going to have a clear out and they'll come in and market it and sell on the spot. Should get it all sold in a one day sale. Then you'll have space to put up a shed and keep your stuff in 🤠
Hi Druid.
Yes, you definitely need the racking to be mounted on concrete. However it's not hard to put concrete bases down only where they are needed to support the racking. Also put a right angle or two in the layout and maybe some support from the embankment behind your equipment to add extra stability if you're putting heavy stuff up high.
FLTs are pretty simple, an oil leak shouldn't be too hard to fix. However to check the cooling system and see if it's had coolant or just rusty water. Head gasket and welsh plug failure can put water in the oil in a poorly maintained FLT. And unfortunately most FLTs get very little maintenance until they fail :(
agreed .. did it in the yard in work ..
and others were bolted to the floor slab
or free standing
and some were even welded to the building :giggle:
remember taking a phone call from Graham Simpson whilst stood on that 'shelf', cutting it down in that last pic. :giggle: and no I don't recall the subject of the call? ..... @Grahams might :ROFLMAO::ROFLMAO: .. end wall also had arms welded on, for steel stock bars
as you say, an oil leak shouldn't be too hard to fix ... when you know what sort of oil you're looking for .. engine or hydraulic ;)
WTH is a Welsh plug? ... core plug??
'sposed to run and drive ... and it's local :giggle: .... 's not a Hyster, but've used a lot of Nissans and they're not a bad truck
JerryRtilt
JerryRtilt
View attachment 50850View attachment 50849
View attachment 50846View attachment 50848
or free standing
Could a Welsh plug be something you put in a Welsh raebit
William127
William127
or free standing
I've got plans to build racking like that down the side of one of my containers, shelves for ground mats, 8x,4s- be so much easier, efficient and tidy to slide them straight off the truck onto a rack when unloading- and steel.
As for forklifts, they've got to be the best value, most fit for purpose bit of plant there is! My mate has a little Nissan, similar to that one, paid 1500 quid for it 5 years ago, works absolutely spot on, lovely to drive, cheap to run. I'd have at least one in the yard and barn if the ground was suitable, but it's either sloped planings or sloped concrete with a steep bit in the doorway 👎 I've got the loader and access to a telehandler, but as soon as you need off road ability, the price goes way up and manoeuvrability goes down! 😔 😆 another mate has an old manitou rough terrain forklift, that would be a good compromise for my place, and over double the lift of my loader for 3 or 4k 👍
used to have five in work - 7t, 4t, 2.5t, 2t and 1 tonner ... were always in use ... a couple weren't enough ... a duck with forks would've been superb outside though and pretty handy indoors too, with the ability to reach over so much
assume you mean on the outside of the boxes ... adjustable arms is a must have ... having the uprights welded to top and bottom of the container would make for a very stable set up and no need for base legs and base concrete.
used to make quite a few of the cantilever type for the timber frame guys, for their yards ... dead easy to make and a bloody sight cheaper than buying them :oops:
William127
William127
Yes outside. Welded to the boxes would make it bloody strong, but it's a rented yard/boxes so anything I do needs to be removable really. Having said that it's a truly dead space alongside a track so it's never going to be useful for anything else. I should do some marking out and have a chat to the farm manager 👍
Only issue is on standard solids they sink faster than a titanic inspection device...on anything other than concrete..and the dislike slopes and things get very exciting on cross slopes...
Someone mentioned moffets they aren't bad at all off road if you can pick one up cheap plus they have the reach function which ruddy handy in tight spots.
only had one of my five on pneumatics ... my yard was 60% planings/40% concrete outside ... never had any issues and often fully loaded (or beyond:giggle:) ... depends how well the planings're put down ;)
one for you all to puzzle over .... had the Harrison wound up this afters to make the 6" x 1/2" nylon disc ... got a job to sort and i really hope this does the trick :giggle::giggle:
the fitting 'cobble' is what I had to hand ;):)
... got a job to sort and I really hope this does the trick :giggle::giggle:
Oh yes .... :giggle::giggle: worked a treat
this goes off in a parallel direction to the man hole it eventually appears in ... must be at least two 90,s in it and have failed miserably to rod it in the past :(
has been giving trouble for some time .. kitchen sink and dishwasher ... is now desperately slow to run away so reckoned a bit of pressure'd aid matters
filled the system with 1.5bar of 'wasser', shut water off at the integral valve in the tee ...... and gave it 150 PSI from me air bottle ....
Pam stood at manhole, backed away pretty rapidly :ROFLMAO:
handball and trowel to remove this lot and gave it a few more goes ...
got quite a few more lumps ...
estimated at 13 yrs of fatberg from us and God knows how much from the previous residents ...... pipe now running clear as a bell ... hopefully won't need this piece of 'kit' again for many years :rolleyes::oops:
it burnt exceptionally well :giggle::giggle:
mission accomplished ... Pam WELL impressed :)(y)
Not a problem on your local salt flats, at 20mph🤣
kicks in, Wales wide, tomorrow 🤬 🤬 went into town Tuesday and have discovered the cruise on the Kia will do a 20mph setting ... makes life a lot easier on the flat and up hill .. can't cope with downhill though ..... had a convoy of white vans behind me after the first mile .... limit starts a good 2+ miles from the town 🤬🤬🤬
