The Sonoff stuff is a piece of pish. Get yourself a basic - 240v l+n in, same out. Chop out the lamp switch and wire in place.
Install app on phone. Hold down button when prompted and it will pair up. Bing you can now control from your phone!
Install Alexa, enable the skill and she will find it. Tell Alexa it's a light and now you can say "Alexa turn the lights on". It's great!
I am not a fan of the tech but we have had a smart thermostat for 2 years which is quite handy as we can control the heating and hot water when we are away through the app on the phone. My wife has smart plugs through the house for various different things like the pool pumps, lights and plug sockets. She is happy to play with them but they can throw Wobblies when the power is cut. The storms the other week was tripping the power and several devices would turn themselves in when the power came back!! I was looking into smart house technology at a recent building show I went too and was quite impressed what it can do if you throw the miner at it. But the money can really start running away with things like curtain closing, why do you need to tell a device to close the curtains!!!
what sort of range do those things have Alex?:unsure: are they blue tooth or wireless ... what sort of current can they handle?:confused: sounds like an interesting method of controlling outdoor floods, with a suitable relay, if required, to handle the draw :rolleyes:
Cyberprog
Cyberprog
Range depends on your wifi signal - they are 802.11b/g/n compliant. The Basic's are 10A, but the Light Switches (T1's) are only 2A. The POWR2 is 15A.
There is nothing stopping you from driving multiple units though, either through eWeLink and a Scene, so the T1's action will trigger the Basic's in your loft, or through alexa by defining a "Room" and adding those devices to that room, and then having an Alexa Routine to handle that stuff.
I have an Alexa Routine called "good night" - when I say "Alexa, Good Night" she will turn off the living room lights, and via the Wifi IR Blaster, turn the TV off too!
A Sonoff Basic, I forgot to add, is £6 or so off AliExpress, dropping to £4 if you buy 10. The T1 light switches are about £15.
modelman093
modelman093
Thanks Angus (y) ..... I'll have a look :rolleyes:.... have always found that a 15 thou gap is absolutely useless on it and IIRC have it set at circa 25 thou :whistle: ...... I'll give it a tad more ... the next time said flywheel has to come off...
only motor I've ever seen with an ali woodruff key :unsure::confused: ... have really got to dog it down or it'll split the key :mad: and I'm clean out of spares :censored:
Old girl's older than me Weller :eek:
modelman093
modelman093
Flywheel nut torque 65ftlbs
PM me with an address and I'll send you a couple of keys.
Cyberprog
Cyberprog
Bit of a result this evening. Found the living room light switch has a neutral at it!
Wired in my 2-Channel Sonoff T1 and I can now get it to turn the Sonoff Basic on and off when it switches on and off also.
very kind offer thank you Angus .... will do (y)(y):cool::)
better find me torque wrench and see what that feels like:unsure: .... then re-calibrate me right arm :LOL: ;)
Jimoz
This cat5 and smart stuff frys my brain. Is it worth getting a newbuild wired with the stuff one point in every room next to tv point? Perhaps a couple in select locations,potential cctv and doorbell locations then just all wired back to one central cupboard? I though wifi was the future?!
Cyberprog
Cyberprog
Yes, in my opinion I'd get it pre-wired back to a central location. Money well spent IMHO, the CCTV I have is all Cat5, Power Over Ethernet too.
Also insist upon there being a neutral in every socket, will allow you some latitude with smart switches or dimmers.
Cyberprog
Cyberprog
better find me torque wrench and see what that feels like:unsure: .... then re-calibrate me right arm :LOL:;)
65lb/ft is about 88nm, or one and a bit ugga-dugga's.
that'll piss the leccies off ..... don't often find a neutral at a switch :rolleyes:
This cat5 and smart stuff frys my brain. Is it worth getting a newbuild wired with the stuff one point in every room next to tv point? Perhaps a couple in select locations,potential cctv and doorbell locations then just all wired back to one central cupboard? I thought wifi was the future?!
Ditto :oops: ........ me too :unsure:
...........Those 'little motors ain't so little when yer's wrestling the damned things :oops:' ..... the two Z1000 engines beat me ... they'll have to stay put for now:cry: ............
:giggle::giggle::giggle: but not for long ;)
seriously heavy, but managed to get at 'em with some juggling ...... they'll be getting 'air lifted' into a new home later .... 'tween the Esab 200 MIG and the breaker pack
left the last one at full sheet width, for now, for some light weight furniture storage and 'cos I'd run out of 25 x 3 flat to lip the roller bed frame :(
was some bit hot here yesterday ... foggy as **** here this morning :oops: ...... got two Houdinis on the lawn this morning :mad: .... waiting for the owner to arrive and collect 'em !!!!:rolleyes:
pretty PO-ed with this sheet yesterday .... brand new WBP sheathing GOS and delaminating before it'd even been handled .... could not be arsed to take it back ... never likely to see the weather, but annoying :mad: all the same
now to get @Delbouy 's placcy pig chassis out o' the trailer and go collect said furniture from Pam's daughter's place.
Cane conservatory suite :rolleyes: ... new conservatory getting started tomorrow, as the current one's over 15 years old and showing serious signs of not lasting much longer:( .... 'least it's a damned sight cooler this morning .... must've gotten through 4 litres of squash yesterday and didn't have a pee all day :oops:o_O ...... was running off me, but the boxes were like saunas !! :(
Cyberprog
Cyberprog
Damn handy when you do have a neutral at the socket though!
Installed a 45mm deep backbox this afternoon, though I now have to trip the finger plate cos it wouldn't fit.
Wifi is great for some things, but when you're running 4MP CCTV over it, I'm seeing 40Mb/s over my normal LAN to the NVR which is well on it's way to causing issues with wifi. With Gigabit ethernet between the rooms I can still stream from my PC to the TV without issues.
'Fraid some o' that's above 'my pay grade' Alex :( ... ....... wish it wasn't :rolleyes: :cry:
meet Houdini #2 & #3 - 2019 :mad:
buggers have been here all day ...... could've been a mistake when I said to Ellie (the owner) that I wasn't worried - no panic!! :rolleyes: ..... bet 'er next door has been having an eppy all day .... so fine :ROFLMAO::ROFLMAO:
Who said pigs can't fly ..... this plastic one ... or at least what's left of it, did a fair impression of a 'low pass' this morning :LOL:
been sat in here since I picked it up for Del several weeks ago ....
but got 'evicted' this morning .... needed the trailer ... :rolleyes:
took the head trees out to give 'em a fresh lick of shiny shite for half an hour and copper slipped all the pinch bolts ....
anyone recognise the tin I keep me copper slip in ...
can not remember how long ago I filled that, from a big bucket of the stuff ..... but it's a looooooooooooong time ago ... still a quarter full :)
those two Kwaka lumps got a leg up after that ....
and wriggled 'em into spot where I wanted 'em , along with three bloody big Record vices, I keep tripping over on the floor.:(
Then it was off down the village to Vicki's to collect the cause of all this effort over the last few days ..... :cautious:
got there just in time to witness their little leccy mower go poof:oops::giggle:... so had to sort that 'fore I could do anything else ... wire busted as it went into the switch .... made her hubby Chris jump ... :ROFLMAO:
hadn't seen Clara for over a week, so a bit of grand dad-ing first, spot of re-wiring and some trailer loading ... bit more grand dad-ing and away back home ... to unload this ....
and a car load of cushions to fit ....
took some persuading into their home for the next few weeks, whilst the new conservatory gets sorted :rolleyes: ... Was not flavour of the month with Chris.....had taken him two days to get the floor tiles up:giggle: ... I laid 'em - properly - maybe 15 years ago :rolleyes: didn't put 'em down to come back up again :LOL:
these took a bit of wrangling in, to find the optimum orientation .....:unsure:
was bloody hot in there again today ..... 34.6C at lunch time in the 'toolbox' next door to it :oops: and could not touch the roof in there:oops: .... as I found out when I put my back against it, juggling the Kawi motors earlier. Cheese cloth shirts are not much of an insulator.:(
Sat having a coffee after all this lot, chilling in the shade .... and Pam says....."right treatment next then " :oops: ..... had forgotten it was Monday :unsure::rolleyes: ....... "no peace for the ......" Druid.
