L
LKSF
Pennine Hillbilly
Which bit?that was annoying ......![]()
One of each - one at the front and one at the rear dependent on which one has the least amount of grip. It's got a bit more muddy down there than I realised during the last few days, but I thought (was told) it would have a bit more grip than that. Surprised it's got normal open diffs.Those axles were favourite for wrecking diffs, which one turned the wheels back or front?
bit harsh on Mrs LKSFI didn't think the 803 had the strength or grip to pull it out, but to be fair to it it didn't struggle at all. I took O/H down with me
, but I don't think she even found reverse on the dumper before i'd dragged it back and out of the mire.
Man and machines in perfect harmony, 3 antiques working together.
Thanks for all your help so far![]()
Looking at some of your earlier pics I did think that the dumper had been semi submerged in water, you need to check the oil in those axles and drop box!
it'd split I think MickGearbox top probably has no rubber gator over the top of the box around the base of the lever!
I'm pretty sure rain water has run down the gearlever, under the gaiter, into the gearbox and mixed with the oil. Mmmm, lovely.
What has happened is the rubbery plastic plastic gaiter shroud cover thingy has gone hard over the years, some rust has formed under it and pushed it away from the gearstick which passes through it. Water has then been able to run down, pass through and into the 'box. I put some gasket sealant around the collar of the gaiter to stop this from happening again for now.
I had to refill and flush it several times, the old hydraulic oil was good for this. What made it harder was stupidly the drain plug is not right at the bottom.
I'd suggest putting the main live eye onto the post first, followed by the lighter eye terminals, spring washer and nut ..... you really want the best surface area contact between that live cable and the nut under it, as possible ... don't really want the current flowing, either through those thin, flimsy eyes, or the spring washerThe starter motor was past its best. I could have tried to repair it, but I don't think it would have been reliable or worth it. Me and electrics don't go well together either, time for a new one.
The starter for these is a Lucas 54 24 25 14, but that number doesn't bring up many possibilities. I did however find a cross reference to a LRS 155, this is the number you want, it opens up a whole load of choices. £125 inc next day delivery, that'll do.
When you're designing a dumper it's a good idea to run the downpipe right where the starter needs to come out. Don't put it to the left or the right, straight down the middle is best.
Then use steel bolts which will rust in solid
Don't put a shield over it, let it get the maximum amount of rain so it corrodes down to the thickness of a piece of foil.
So when someone eases it to one side to get the starter out it just tears.
I'm really looking forward to building a new exhaust, but that aside it now turns over and fires up much quicker than my van which is about 30yrs it's junior.
We celebrated being mobile again by putting the bin out:
In other news I flipped the skip up and went at that stuck ram bolt like Tiger Woods with a sledgehammer, it gave up and slid across
The bottom one isn't playing though (I can't get a good swing at it down there). I'll try some more, but might have to fall back onto the earlier suggestion of leaving the lower half on and taking the piston out, we'll see.
Fitted some new mudflaps and a steering wheel spinney thing. Still haven't sorted the BMC out, but am on it soon.
