Avant / Multione Wheeled Loaders
only if they're 'liquid withdrawal' type (i.e. designed for FLT use) all others are vapour discharge ... can get vapour out of FLT bottle if you stand it upside down or with the arrow facing up, on its side
conversely all vapour discharge will give liquid if stood upside down
's why you never lay a propane or DA bottle on its side if using it for oxy cutting - always stood up or you'll possibly/probably get a liquid discharge depending on how full/empty it is
CO2 bottles are similar some are vapour, others are liquid and have a dip tube to the very bottom of the cylinder - can usually hear it rattle when bowling them about.
FLT LPG is 18kg and has a clockwise male thread and dip tube and arrow. Normal Propane is 19kg bottles with no dip, and reverse thread female connection (POL) You could make a FLT work on Normal if you fabricated a hose and used the bottle vertically upside down I suppose!
Not lazy your body will thank you further down the line
Did it again today but this time with the breaker for the mini digger.
I am trying to be sensible and making things easier to get to with the avant round the yard so you can just pick it up and load it on to the truck.
Talking of bottles-
I've bought a POL to POL hose. I want to use it to fill my baby 3.9kg bottles from larger bottles.
Suggestions of safe procedure? Looking at Youtube they just turn the big bottle upside down and open the taps, flip flops and all. How do I know when its a safe fill weight, have it on scales?
William127
William127
I'm seriously tempted to buy one of those mini shipping containers that seems to be in every auction at the moment so my Giant mini loader is never blocked in at yard. Things like loading ground mats or a few slabs are a doddle with it, but if I have to open a container, move a digger and/or dumper then it's easier to just do it by hand 😒
That's exactly why I've changed things round in the yard, otherwise I'd still hand ball it all.
Talking of bottles-
I should know the answer to this .. but never tried it .
Provided they are both designed to the same pressure (6.3bar??) then should be okay.
Talking of bottles-
I’ve tried exactly this and didn’t seem to end up with much getting in to the empty bottle somehow. Not sure if it freezes up, or if once the pressure equalizes the liquid doesn’t flow for some reason?
Got my eye on this one in local auction and saw this setup on the Irish trailers, good setup
Had a 755 this weekend, ruddy capable and still surprisingly nimble...but with the weight pack and big bucket and forks it's hardly "compact" and you know it's on the ifir 😊😊
The 755 is practically a delicate little rose compared to the 860. They actually have gone past the point of being a compact loader. Whilst they are still towable. They are, size wise, competing with far more capable machines.
