Avant / Multione Wheeled Loaders
Yes but surely you’ve been lucky these last few years with new prices increasing by huge margins and thus bringing used prices up with them?
Will you be able to say the same next year or the year after that etc?
Who cares - the owners will be drinking rum punch on their Caribbean islands unable to spend what they’ve made as it is!
HuntingHicap
HuntingHicap
I just work here mate, not my business....I couln't really say, but since brexit has weakened the pound we also send a lot abroad, do really well on them as well.
Does my bucket look big?
I reckon I've enough nose weight 🫣🤣
Not had much work for my avant recently....but it's bloody handy to use in the yard, no pulling you whatsit out trying to move heavy things....even the 9inch bucket off the 2t was moved the other day with the avant forks...hight of laziness I know
why grunt when you have mechanical handling on tap :rolleyes:
one of the reasons I've been after a fork lift for a while ... jump on and lift .. quicker than winding up the 'Drema for odds an' sods ;)
William127
William127
2 seater sofa, carried it indoors at home no problem on my own but using the forklift made wrapping it/unwrapping it and sticking it on the shelf far easier 😀 😄
William127
William127
the 'dip tube' in them has a 90 deg bend on the tip and extends to the bottom of the tank ... 's why there's an arrow on the bottom of the bottles for orientation to keep the tip at the bottom of the liquid whether vertical or horizontal
Far better answer than I could give👍
I'd have said - yes 🤣
Do they all have a dip tube in? Ones I've seen "modded into stoves" didn't
Not lazy your body will thank you further down the line
only if they're 'liquid withdrawal' type (i.e. designed for FLT use) all others are vapour discharge ... can get vapour out of FLT bottle if you stand it upside down or with the arrow facing up, on its side
conversely all vapour discharge will give liquid if stood upside down
's why you never lay a propane or DA bottle on its side if using it for oxy cutting - always stood up or you'll possibly/probably get a liquid discharge depending on how full/empty it is
CO2 bottles are similar some are vapour, others are liquid and have a dip tube to the very bottom of the cylinder - can usually hear it rattle when bowling them about.
always used to say the same to my blokes ... " if it's a grunt of a lift get a fork truck and use it - we've got five - don't struggle " was better than having 'em off sick, with a bad back
Jimoz
Soon to be let the robot lift it. These fire doors arent getting lighter have some 44mm atm that seem heavier than the 54mm 1 hr ones. How long till these robots are main stream?
