1997 lifton dumper question/issue
  • Thread starter heritage machining
  • Start date
heritage machining
heritage machining
Yes I will today I did try to adjust the stops on the lever arm that the cable from the pedal goes to but it made no difference so I put it back to what it was it looks very similar to the hydrostatic drives on the John Deere mowers
heritage machining
heritage machining
Pics of pump
These two hex head caps seem to be your f/r arv’s but I guess looking at them, they are adjusted by shims, if it’s better in reverse than forward take the springs and shims out and swap sides! Try not to lose parts the oil in there will push parts out when the caps are off!
heritage machining
heritage machining
The flow from the pump and the fast slow lever goes up to a separate shuttle valve for fwd reverse
heritage machining
heritage machining
Hose comes off the bottom of the pump up to the valve in the top right of the pic then one to fwd and one to rev
heritage machining
heritage machining
Yes it's the manual one 4 hoses 1 feed off the pump 1 return a fwd and a rev standard type of reversing valve but unsprung with a detent so it stays in fwd or rev or neutral
heritage machining
heritage machining
That's what has me stumped as in theory it should be the same unless there is an issue with the motors but I done think so
lack of flow in the forwards direction ... damaged valve shuttle?
Change the forward hose for the reverse one see if it changes anything!
heritage machining
heritage machining
When I got it it had the slow or no go in fwd and good in reverse so after inspection of the shuttle valve and finding damage on the sliding part which I think was because someone shifted from fwd to rev without lifting their foot off the go pedal I thought that replacing the shuttle valve would fix my issues it has helped but it's still not right yesterday I got a new set of hoses from flowfit so I will fit them and see if that's it if not I will start swapping fwd reverse round to see if I can make the fault replicate in t other direction
if that's the case it could well be more than just that valve :unsure:
heritage machining
heritage machining
Indeed it could but I would be surprised if it was the drive motors as they work well in reverse
heritage machining
heritage machining
Seems a lot better after hoses and pipe replacement will go up a reasonable gradient not sure what it's supposed to go up seems the same in fwd and rev only thing I have done I filled it with 32 oil then realised it needs 46 will it make any difference or shall I drain a bit out and put in some 68
heritage machining
heritage machining
So is it worth draining the 32 weight oil and putting in 46 still looking for a filter for it too it's 45 diameter by 80mm long judging by the filter housing as I don't have the original it was missing when I got it
