Im trying to ..... à lad had been Friday apparantly and they told him they would hold it till Wed and if they don't hear back from him then its mine
guessing he means buy itBy it.
7.2t front axle weightIn the UK our max on a 4x2 is 18t but I doubt there is any difference
Check the axle weights for the front axle
Often lorry's that size over here are built on stretched tractor units and have stupidly low front axle weights.
Over here I've seen 2 different bin lengths and 2 different wheelbase on 18t hookloaders. Obviously the shorter ones will have a tighter turning circle.
I don't know how your taxes and cost work over there as to whether its worth it but if you are looking at that size the 26t on 3 axles are actually more maneuverable especially if they have a tag axle
Most modern trucks with adblue, tend to produce a lot of condensation out of the exhaust while warming up.Went to look at the merc wagon this morning and went "double de clutching" the 8speed round the area for 1/2 hr - all good although noticed some white smoke under load for a bit that seemed to go after a while ..... bloke with me said egr ....me I know knothing.
View attachment 32073anyone any suggestions ? Normal ?View attachment 32074
We don't get any hassle locally at present, I saw the chassis was marked, I think it indicated where hook gear had to be mounted to have middle of skip in best position for weight distribution ... but there will be no wiggle room with 8t on it , it will be arse against the headboard to get it in a 5m skip - I don't know where the centre line weight wise of an 8t in transport position is but im guessing the front axle may be quite heavyThink that's about standard
I don't know how much bother you get over there but it
Might benefit taking it to an axle weighbridge with the machine on to see where its best to position the machine for transport. Then mark the body so you know you 100% legit.
There's a fair bit of weight in counterweight on an 8 ton and I'd bet it could be fairly ar*e heavy. I know the extra 35mm thickness added to the middle on a 2 piece taki 290 adds 210kg so there must be a fair bit of weight to begin with.We don't get any hassle locally at present, I saw the chassis was marked, I think it indicated where hook gear had to be mounted to have middle of skip in best position for weight distribution ... but there will be no wiggle room with 8t on it , it will be arse against the headboard to get it in a 5m skip - I don't know where the centre line weight wise of an 8t in transport position is but im guessing the front axle may be quite heavyView attachment 32101
After the chassis work and mounting of the hook it has to go back to be checked and it has new plates to suit - which are ministry plates as such yes.I don`t know what the score is over there, do you have a ministry plate, rather than the manufactures plate that says legal weight and design weights?
If there is, and the design weight is higher, (over here) its a paper work submission to change the plate to the higher weight and change the tyres to ones with the correct load rating for that weight (you have to specify on the paper work), usually no need to be checked, it will be done at the next MOT test.
Yes looking at it I imagine it's going to sit a bit heavy on front .... but what's the expression "if it's on its gone"There's a fair bit of weight in counterweight on an 8 ton and I'd bet it could be fairly ar*e heavy. I know the extra 35mm thickness added to the middle on a 2 piece taki 290 adds 210kg so there must be a fair bit of weight to begin with.
It may be straight forward to get the front axle weigh increased, if the design weights allow.After the chassis work and mounting of the hook it has to go back to be checked and it has new plates to suit - which are ministry plates as such yes.
think you might be pushing it a bitWe don't get any hassle locally at present, I saw the chassis was marked, I think it indicated where hook gear had to be mounted to have middle of skip in best position for weight distribution ... but there will be no wiggle room with 8t on it , it will be arse against the headboard to get it in a 5m skip - I don't know where the centre line weight wise of an 8t in transport position is but im guessing the front axle may be quite heavyView attachment 32101
That's what I was thinking but don't want a f**k up and to be wishing I'd gone 6x2Right it's a 7 t axle... A 8t machine is pretty well balanced with the boom packed down. And so the diggers going to be sat spreading the load on both axles....
It'll be grand
You won't.That's what I was thinking but don't want a f**k up and to be wishing I'd gone 6x2
No feasible its 2.5hrs away .... might be gone anyhow, will find out Wed.Will the dealer, tare weight it for you, or even better weight it with your machine on? at least then you will be 100%
