Just a bit of water,Looks like interesting work Gus. What's in the bag?
Slows the ram down before it gets to the end of the stroke, so comes up fairly fast till over 3/4 up then slows down. It's to stop it banging up. It's annoying it comes up quick then as you try to get the last bit of reach just slows downWhat
What’s that?
Never touched the hammer line yet, will try next time on it. I have found if you use the blade while travelling and let go of the travel levers it has a tendency to hold onto the right track lever.I can't say I'd noticed! I'll check when i take it off the trailer later.
Interestingly on mine, if you press the hammer whilst slewing it'll go round like a helipcopter! Does sugegst there's scope for speeding them up a touch. Does yours do that?
Do you have much play in any of the pins? Never had a new machine before but seems to be alot more play in it than I would have thought
How much do you stick in the ground for those big field gates? I know a domestic fence is about a third of the fence height in the ground .Got this gateway sorted today. Little Bobcat was very handy to lift the heavy old oak posts about, and level some stone for a soft patch.
I know when I used to put in what we called triple 8's (8" by 8" by 8 foot long) new oak gate posts rammed in it was 3 foot deep then dig out a foot all the way round it and a dry mix back fill. If hand dug in it was a 3 foot by 3 foot by 3 foot deep hole then post in earth packed around it for 2 foot then dry mix and topped off with soilHow much do you stick in the ground for those big field gates? I know a domestic fence is about a third of the fence height in the ground .
Knocks the spots off any micro on sticks I’ve used. Like, twice as much power and control. Really powerful machine for its size.i do like that little E10, how you rate it doobin ?
Im a kubota fan and they have a side lever model out with servo controls, wonder how it compares.
unlikely, on back'ards like thati think for drainage it would be ideal, no having to fetch trailer for the 3 tonner... Theres an hour saved immediately.
Will have to go shopping next year i think.
Out of curiosity, what hitch and buckets did you go for ? is it a klak ?
