Good afternoon guys! I’m new to the site and the industry to add!
Basically I’m trying to see if their is any advice out their on starting a hire business in welfare cabins etc, the cost of a brandew cabin won’t work financially wise so my best option is a second hand one to get started. I’m stuck on where to find out where to go for advice on making sure I have the correct documents to be legal to do this buisness I understand the Insurance side of things to an extent..and land to keep units on.
Is their any other documents I would need and any information is greatly appreciated in advance.. thanks you
ryan.
I had a couple for my own stuff and now down to one for the time being, although that's probably going too.
Mine were never hired out to anyone else, did advertise it and got little intrest. Rates vary from £100 off eBay to low 200 a week.
There is some association for welfare units never got further than looking as its some yearly fee scheme
You'll need hired plant insurance no idea on costs as mine are only insured for my own use/jobs.
Do you have a decent tow vehicle? as they tend to be north of 1.8t, it's not the weight that's the issue more towing a badly designed brick that are absolutely crap for towing. Transport fees aren't great by te time you factor in fuel and time plus once you charge transport you'll need a tacho.
Will need yearly electric testing at over £200 a pop. Some get tested every time they go out which is fine for large companies with sparks on the payroll.
Toilet emptying is your next issue anywhere from £25-£60 a week which again is fine for the large companies as they will have their own units or preferential rates for national company. I did consider using the unit and hiring a separate toilet as they can be hired in for less than the emptying cost.
Maintenance and repairs is your next issue unless you can fix everything you'll need to get friendly with a fitter as there will be times where something needs fixing/replacing and parts/fitting fees quickly add up.
You'll also need to allow time for it to be cleaned out after every hire, you can put in your terms about needing to be cleaned before collection but it won't be to a standard that will be good enough to send straight out
Mostly people who hire kit, tend to care very little, so your kit will get damaged and getting paid for repairs is not easy.
small tool hire on facey will probably earn you more money.
