K
kev G
hi, i have a terex hd1000, while using it, it cut out, and now i have no electrics at all. Tried a new anti start module, nothing, turn the key and no dash lights and no starting, any ideas, cheers.
earth leads fell off the chassis? or cell gone down in battery or main +ve feed broken to dash / ignition switch .... time for some creative wiring to bypass stuffhi, i have a terex hd1000, while using it, it cut out, and now i have no electrics at all. Tried a new anti start module, nothing, turn the key and no dash lights and no starting, any ideas, cheers.
battery new, checked earth lead, got 12.65v at ignitionearth leads fell off the chassis? or cell gone down in battery or main +ve feed broken to dash / ignition switch .... time for some creative wiring to bypass stuff
Ok, thanks.wow ....
lorra Qs....
and no pix
I would guess that -- yes the starter is running all the time you have the ignition switch/hot wire held in start position
I would also assume that your stop solenoid is being energised via the crank position on the switch, but not being fed a live when you return from crank to run position .. so you need to track down that fault first, so you can at least run the engine to try to isolate some of the other faults (which may also be due to no constant live coming from the ignition switch in run position)
Ok thanks for that I'll pm him tomorrow.JD6820 has far greater knowledge of these than I do for sure ... I am generalising in my responses ... he's actually seen/worked on said beasts ... and knows their foibles..... I'm just chucking general ideas in the pot![]()
so there's a live feed to one side of the switching terminals in the relays,Ok, thanks.
There's about 7 wires coming out the ignition switch and I'm not sure where they are all meant to be going and doing what, a traditional wiring diagrame would be great but the only one i can find doesnt really give much info.
I've traced everything back starting at the battery and working backwards and everthing seems to come to a dead end at the relays...like power going into them but nothing out even when the ignition key is at run and crank positions.
I even then traced from the ignition switch working backwards that way...but again all dead at relays.
so to clarify there's 12v into relays on red wire but absolutly nothing out on any of the other 3-4 wires coming out of relays, obviously there's ground out of each one then approximately 3 colored.
I'll try again tomorrow with a fresh head.
PS: Brought a brand new 3 ton Sany last week and loving it....but no dumper to go with it now, been working flat out for 3 months with new digger business.
See document above and look at the first two diagrams the colours are all abbreviated and there to see.Ok, thanks.
what a can of worms ..... WTF is this 'anti-start module' JD and what controls it ?See document above and look at the first two diagrams the colours are all abbreviated and there to see.![]()
