Government proposal to change trailer licensing regulations.
jd6820
jd6820
I've read into this as was unsure myself. Here is a link to the document used by the DVSA to inspect trailers and the guidelines they follow.
https://assets.publishing.service.g...hicle-approval-inspection-manual-trailers.pdf
It would seem that as typical 3500kg trailers are not 'semi-trailers' i.e. not designed to impose a significant load onto the towing vehicle then the maximum weight the trailer can be is the plated GVW as stated on the plate unless this figure is not given in which case the maximum axle weights are used, which usually add up to make the GVW.
A semi-trailer appears to have lets say a GVW of 41000kgs and this is made up of three axles rated to 9000kgs AND an imposed load rating of 14000kgs. Which doesn't appear to be the same as balanced trailers such as Ifor's?
Now, the real question is are they gonna get you to unhook a trailer to prove it's overweight when you have just rolled the towing vehicle off the bridge to get the trailer axle weights and the trailer alone is 3500kgs but imposing a load on the towing vehicle? I'd say not as long as the rest of the outfit is below the allowable GTW. However, they would assume some load is being imposed and probably argue that the trailer was only designed with it's own 3500kg GVW and is overweight just like you can't exceed your cars GVW without potential of being fined.
Justme
But then they would be counting the same weight twice.
jd6820
jd6820
Still doesn't get away from the fact the manufacturer has designed the trailer to work within certain parameters to get type approval you alter those parameters and the trailer enters a different type classification. That extra nose weight is still being put through the trailers own structure that was designed with certain loading factors regardless of the axle capacities. The tow hitch is subject to the full load which in this argument seems to be over the 3500kg plated weight.
If we really want to split hairs, have you ever tried to load a trailer and get the axle weights up to maximum whilst having a significant nose weight? My bet is one of the axle weights would be over the plated weight before you got enough nose weight that the trailer was carrying much if any more than the 3500kg allowable? This is purely by nature of the design of balanced trailers? Not sure this is a productive discussion? :ROFLMAO:
To be fair trailers would have been designed and tested beyond their max rating and the brakes systems would also be able to cope with more.
Justme
My triple 3500kg has 3 x 1500kg axles. When I first loaded it the nose weight was too high when fully loaded. But with the 3 axles you can shift the load to get it right. My twin 2.7t has 2 x 1350kg axles so you would need to load spot on to get the max.
Nose weight will also be affected by vehicle used as the ball will be at different heights. Even if in spec for height you can have about 2" variance. Vans 4 x 4's and pickups dont always have balls in spec.
Justme
Show me where it says that.
How do they weigh you?
Yup a pressure plate via the wheels driven over them in most road side stops or a bridge if a fixed site. All weigh via load applied via wheels.
Canal Navvy
Canal Navvy
Glad I didn't ask if I could tow my unladen tt3017 behind the other half's VW golf now 😈
Not arguing with how they weigh you in practise, but if they did weigh the trailer separately, which they are entitled to, you’re over. Unless you can show an authoritative source that says they aren’t allowed to. (Preferably not a caravan forum) I think this thread has got confused over the law, (which nowhere says you can add weight to a trailers‘ GVW via the imposed load on the coupling) and how it is (usually) enforced.
Justme
Getting back on topic. Ignore the crappy title.
